Axe Cp Problems (No Lift)
AB, CANADA
I had a crash (bad one) replaced Main Gear, Shaft, right servo and others, put it all back together as the book and numerous peoples help, trimmed it, tracked the blades, but now i dont have any lift, holding onto it and running it up it starts to push downward about 1/2 throttle, on the floor when i run it up and down it will lift on the downward side??????
FL
RE: Axe Cp Problems (No Lift)
Sounds like you did follow the book... but it is wrong. At least the CP-L (V2?) book's exploded diagram of the head and grips was.
Most likely you have the blade grips reversed.
Thus you are getting negative pitch when applying positive collective.
