Helimax This is for all your Helimax questions and comments.
Axe CP Issues
Old 03-18-2009 | 02:34 PM
Default Axe CP Issues
My Axe CP seems to have some issues, firstly, it jumps into the air which makes it somewhat uncontrolable when its in the air, secondly, i keep busting main heads, 2 in 3 days, not sure what to do?
Any help is appreciated.
Old 03-18-2009 | 08:29 PM
Default RE: Axe CP Issues
Check for binding along the main shaft, where the center hub is and the slide block slides on the center hub. I had a cracked slide block and it would jump up about 3 feet.
For blades, I stopped using the woodies after 4 sets in less then an hour I went with these:\
http://www.helidirect.com/235mm-glos...axe-p-4340.hdx
They work for the AXE V2 with the bell hiller mods.
Dru.
Old 03-18-2009 | 10:17 PM
Thanks Dru, I managed to put it in the dirt hard today, new parts coming tomorrow, mostly top end parts, I think I have the pots all messed up, I think I have the bottom two ok, but the top one I have no idea. i thought I could just turn it all the way one way, then the other and set it in the middle, but it seems to turn continually?
Old 03-19-2009 | 01:55 PM
You have to look VERY close and you will see a very small contact point. It makes it a little bit easier if you magnify it with a good magnifying glass.'' When you find it, mark it with a pen so you dont loose it againi.
I ended up using all my own radio gear. it helped out a lot. I do not have to worry about adjusting the 3 in 1 all the time.
Dru.
Old 03-20-2009 | 06:47 PM
The 3 in 1's pot(s) should NOT rotate more than about 270 deg. (~3/4 rotation).
If it is turning continuously, something is wrong.
Old 03-22-2009 | 06:34 PM
THANKS for that link,they have parts for 3 of my 4 heli's,not a large stock,but its a bookmark worth keeping...........
Old 03-22-2009 | 10:01 PM
r_wiliams, I have (4) of the 3 in 1's and only one will only turn 270 degrees. The rest will spin all the way around. that is one of the reasons I went with all separate items on mine.
Dru
Old 03-23-2009 | 10:24 PM
Seperate items? how? where? HELP!!!! lol
Old 03-24-2009 | 10:30 AM
motodude11's Avatar
he means a seperate gyro and esc instead of the one unit used on the stock axe
Old 03-24-2009 | 01:29 PM
Yep. I used my RD6000 Tx, Rx, GY240 gyro, 25 amp ESC, (4) HS55 servos and a home made belt drive conversion for my AXE. You can use a HBKII's tail on the AXE with a few mods. It fits right on there and holds the tail like a bigger helicopter does. There is a LOOOOOOONNNNNGGGGG thread on RCG. My posts are on page 446 or there abouts.
Dru.
