Resetting Hitec 5645 to factory
TX
I just purchased a plane that had a Futaba receiver and all Hitec 5645MG servos. I don't fly Futaba so I pulled the receiver and replaced it with a Spektrum AR8000.
I noticed that the servos were moving much slower than I thought they should and that some continue to move after the transmitter stick hits the limit. I called the previous owner and he said that the servos were programmed for a Futaba receiver. Unfortunately, he isn't available to reset them for me.
I have questions:
How can I set these back to factory?
Is there anything I should do to them for use with a DX8 transmitter? I have never programmed servos and always just use the transmitter to program.
Can they be made faster? Maybe I'm spoiled-I use Savox almost exclusively and they seem so much faster than these. And they just work without having to worry about a programmer.
Any help appreciated!
Steve
RE: Resetting Hitec 5645 to factory
ORIGINAL: stevehookem
I have questions:
How can I set these back to factory? Is there anything I should do to them for use with a DX8 transmitter?
Any help appreciated! Steve
Please refer
Alan's Hobby, Model & RC FAQ Web Links
sub section:
"Servo - Digital & Brushless Servo, Programmers and Software" e.g.
. Digital Servo Instruction Videos - Programming with HFP-10, HFP-20, HPP-21+, HFP-25
. Digital Servo Programming FAQ - Center & End Point - Adjust to Match TX
. Digital Servo Programming FAQ - Center Point May Vary - Why & Correction
. Digital Servo Programming FAQ - Center Point & End Point variance - Why & Correction
. Digital Servo Programming FAQ - Programmer is Preferable to using EPA & Trims on TX
. Digital Servo - Burnout. Cause & Prevention
. Digital Servo - Delayed or Slow Centering at Start up #01
. Digital Servo - High Resolution & Jitter - Why & DIY Cure #02
Also be wary of the different EPA settings between transmitter brands:
EPA, ATV, Dual & Triple Rates, Expo Differences & Caution includes ESC / BEC Set Up.
Much more information available under sub sections
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan T.
