I hope someone can help with this
CA
So Ipurchased a kit off of ebay a while ago.http://cgi.ebay.com/Savage-Hop-Up-EL...item19c5d31184. Ihope Idid it that right anyways there is the link so Iput it on my savage today and Igot a problem when Ihit the gas the rod that goes back to the bell crank Ithink its called for the throttle bends hella bad any ideas why Im not sure if anyone is familiar with this but Icould sure use some ideas.
RE: I hope someone can help with this
thats called the ofna throttle mod. when i was working on a homemade version, i watched this video quite a few times to get it right.
http://www.youtube.com/watch?v=7-p2w659bXo
how about you chuck a picture of how you set yours up, from there we can see exactly whats what
sorry, i had just edited my post, did you put in everything that came with the ebay purchase? i see on your picture that the throttle return spring and linkage collar is missing (mind you, thats not the issue here).
so when you "gas it", the throttle linkage (thin metal rod) bends? does the carb open at full throttle?
CA
Yeah I never finished putting it together I got to that point and gave up on it.THe throttle opens fine but the rod bends hella bad.
when i was making my own linkages, i tried using the metal rods from coat hangers. the linkage would bend and flex everytime the servo would apply load on it...
you very well could have a flexy linkage there. try using the setup with your original rod. or if your DIY, you can go to the lhs and buy just a long linkage rod and using two pliers, shape the linkage to your liking. the linkage metal rods that you get from your lhs can handle the load which a servo puts on it
i hope this helps
i hope this helps
CA
Icontacted the guy Ibought it from and he told me to move the throttle stops farther down the rod. That did keep it from bending now but now Ihave the problem of Idont have as good as response from the trigger Ihave to pull it pretty far for it to start reving the engine I guess its one of them things Igotta live with. Anyways here is a picture of the finished product.
My Feedback: (31)
KY
Adjust the throttle rod to where when it is at full throttle, the carb is just opening all the way. Then, make sure it closes back to idle when you let off, and if not, you may have to play with it. It should work with some fiddling.
