help or i'll go crazy
ok, trying to start the break in on my nex x,and my first nitro. it wouldnt start at all before, I adjusted the idle adjustment scret cuz it looked like it wasnt open enough. and im messed with the HSN, i can not get it running for about 10-20 seconds then it shoulds like it locks up and kills. not sure what to do.someone please help
RE: help or i'll go crazy
ORIGINAL: bb942
WI
Aww man I wanted to see him go crazy . Yea lean it up like a 1/8 of a turn until it runs leave the glow plug ignigter on it for a bit and blip the throttle to keep the engine from bogging down.
this same thing happend with my tornado bb and i leaned it out richened it up every thing. i could only get it running for like 20 seconds. and i found out that i bought it and it already had a broken clutch spring.and the gas tank wasent sucking any gas in it.
so advice to everbody, dont by a tornado!
thanks guys.i'll give it a try tomorrow.if it doesnt work i might be forced to take it to my hobby store and pay $30/hr to have it looked at [&o]
WI
Fix it yourself man its not that hard. Its proably something silly like a bad glow plug or low idle. Let me ask you this when you start it up when does it quit when you give it throttle or if it just sits idling? If it dies when you give it throttle its loading up with fuel lean it out a bit until you can run it still rich, but not quiting. If it quits while idling(cold engines do it alot) turn the idle speed up a hair. Also preheating the engine head helps alot use a hair dryer or heat gun.
well right now i kinda have it where i can start it and it will stay going.i think the idle is to high cuz it kinda wants to push the car forward and after awhile it starts to. i have had it running but after awhile the temp got up to 230 degrees so i killed it cuz i heard thats to hot for break in and the temp was still on the rise.im not sure what to do and its just getting irritating. i REALLY dont want to (if i havent already) damage the new engine.
OH, and it wasnt kiling but it seemed like there was a lot of gas or moisture coming out of the exhaust.not sure if thats normal
NY
Yep you want, or at least I, want moisture coming from the pipe during break in. If the truck is moving forward, then yea, the idle is slightly too high. And by the sounds of it, it leans out as the tanks go on, which is a typical problem of the Sav. It has a half-tank lean issue, that, is self-explanatory, but I will explain it nonetheless. After the fuel gets below half of the tank, the truck starts to lean out, so you should account for that. Just richen it up until it stops rolling forward, and take it easy for the first tanks.
115 hits about me going crazy...interesting. well i'll do my best to get it going.hopefully i wont pull all of my hair out first
WI
On break in you want to get the temp above 200 degrees. Let it cool down at BDC (bottom dead center) and then go again until it gets up there.
ORIGINAL: bb942
well now that I know the temp is ok, how high can it get before i should stop it on break in? and, i wasnt leaving it on the ground. I had the wheels off the cround but i did put it down and it did want to go forward. thanks for all the help everyone
