HPI big bore shocks
HPI big bore shocks
hi i was wondering if these are good shocks? and also do they bolt up to where the original stocks shocks go? its a savage 21 if that makes any difference. thanks
phil
phil
WI
RE: HPI big bore shocks
you could and yeah they fit in the originals spot but I would just change the oil weight and get differnt springs to suit what you need
will save you the cash to buy something else
VT
yeah i agree, i run 30wt and black springs and i like that with 7k diff oil while where talking about set ups i also run on the lowest ground cleance setting with a preload clip on 4 of the shocks so of the 2 shocks per wheel one has preload, but i may try a higher mount...
the lug
the lug
VT
yeah it gets pretty disgusting after a while i'm gunna put these on some how... http://www3.towerhobbies.com/cgi-bin...7&I=LXMZA5&P=K too keep stuff out
and all that crap in there messes with your seals...
the lug
the lug
WI
ORIGINAL: rclugnut10
the lug
the lug
the shocks on the savage x are 14.4 x 117 x 1.4mm x 26 coils
VT
like i said i'll make um fit i can always cut a strip out of the side to shorten up the radius and CA it back together then silicone in to the body and that little rubber thingy thats right about the spring cup so you don't destroy your shocks when you bottom out
the lug
the lug
