THE Official HPI Savage Flux-HP Thread
#151
LA
RE: THE Official HPI Savage Flux-HP Thread
Installed my diffs last weekend. They work great! Much more heavy duty than the stock diffs.
I am very pleased with my flux! Nice truck!
So what do you guys think is going to break next now that the diffs are solid?
#152
TN
That's what I'm wondering too...
ORIGINAL: FE_Chris
#153
TN
Two questions regarding the new bulletproof diff sets:
1) What is the difference between the the heavy duty grease that comes with the set (#Z164) and the other HPI heavy duty grease you can buy (#Z162)? Is one better than the other? Does "heavy duty" mean 100k?
#Z164 - http://www3.towerhobbies.com/cgi-bin...z164&search=Go
#Z162 - http://www3.towerhobbies.com/cgi-bin...?&I=LXXJ61&P=7
2) On HPI's site, they recommend using the composite gear box / bulkhead set with the new bulletproof diffs... so should I go ahead and upgrade this at the same time or should I wait to see if mine breaks? Has anyone else seen a benefit in doing this?
#102272 Composite Gear Box / Bulkhead Set - http://www.hpiracing.com/products/en/102272/
#154
ORIGINAL: Allgood_73
1) What is the difference between the the heavy duty grease that comes with the set (#Z164) and the other HPI heavy duty grease you can buy (#Z162)? Is one better than the other? Does ''heavy duty'' mean 100k?
The Z164 is the heavy duty black grease - 30000 Weight.
The Z162 is the heavy weight white grease - 100000 Weight.
#155
ON, CANADA
that hpi diff case part you listed is the stock flux parts, which is also an upgrade for other savages. It's already in the flux.
#156
TN
Thanks t9dragon! They need to clearly print it somewhere on the tube or in the descriptions to let people know that. Is 100k weight always the way to go? That's what I hear most people are running.
Perfect!!! Thanks for answering this generis. It's nice knowing I don't have to buy another part.
ORIGINAL: t9dragon
ORIGINAL: generis
#157
ON, CANADA
I use silicone diff lock from ofna 50,000 wt, and I love it completely. I don't know how the grease would react differently from the silicone oil.... maybe that's comparable even though the numbers are different?
#158
ORIGINAL: t9dragon
ORIGINAL: generis
I use the grease between the bevel gears and pinion gears. Inside the diffs I use either Ofna or Traxxas diff fluids.
Also the manual has the wrong part number listed for the 4-gear Spider gears in the diff. The part # listed is for the old 2-gear diff.
#159
Hmm, I wonder what the weight is for the green heavy duty grease from HPI. #Z168, iv'e been putting that on my diffs
#160
ORIGINAL: IceWindius
#161
ORIGINAL: t9dragon
HPI's website says it is ''HEAVY DUTY GREASE (10G)''. I am not sure what exactly the 10g means. But it is used on the Baja B5, so it might be thicker then the Z162 grease.
10g probably means its in a 10 gram tube...
#162
TN
That's correct... 10g stands for 10 grams:
SPECS: Tube Size: 0.35oz (10g)
ORIGINAL: supertib
ORIGINAL: t9dragon
#163
TN
t9dragon, sorry for the noobish question... but could you show pictures of what you greased compared to what you put the diff fluids in?
I just purchased all of the following in order to have everything I might need:
I know the slime is used for o-rings, not for the diffs, but I just listed that there since that was in my purchase.
Which silicone or grease do most people recommend and where?
Ofna Silicone Diff-Lock Oil 120,000 Weight
Ofna Silicone Diff-Lock Oil 50,000 Weight
HPI Heavy Weight Grease #Z162 100,000 Weight
HPI Heavy Weight Grease #Z164 30,000 Weight
Associated Factory Team Green SlimeHPI Heavy Weight Grease #Z162 100,000 Weight
ORIGINAL: t9dragon
I use the grease between the bevel gears and pinion gears. Inside the diffs I use either Ofna orTraxxasdiff fluids.
#165
I would have to say that Diff fluid is better then grease because after a while the gears make voids and air pockets around them selves and your Diff just gets more open because of no resistance. With fluid the resistance is always there [sm=shades_smile.gif]
#166
TN
Ok, so fluid it is in the diffs... but which one? 120k or 50k? What difference will I notice?
t9dragon... I'm new to this... so what are the bevel and pinion gears? Are the located in the diff also or is that the gears that the motor connects to?
#168
TN
Ok, now I can vision it much better, thanks for the explanation. So grease on both the bevel and pinion, and OFNA oil on the spider gears... got it.
Do you recommend 50 or 120k on the spider gears?
Do you recommend 30 or 100k on the bevel and pinion gears?
Lastly, If I put both grease and silicone in the differential case, it seems like they would splash and mix in together when the gears are all turning... correct?
Sorry for all the question, I just can't find a video on youtube for this or any good tuts.
#170
#171
TN
Perfect, thanks! I haven't opened up the diff yet... hence all the questions regarding the layout. I'll let you know how it goes in about a week or so. Thanks again man.
#172
TN
Brake cleaner is safe on the diffs? Any brand or type you recommend? I'm guessing just pore it in and wipe it down until its dry... correct?
ORIGINAL: bigwaltc
No you should not mix them open it up clean it with brake clean then put your oil in it [sm=shades_smile.gif]
Lastly, If I put both grease and silicone in thedifferential case, it seems like they would splash and mix in together when the gears are all turning... correct?
#173
The thicker the oil the diff will act like a posi rear end and both wheels will turn at the same rate [sm=shades_smile.gif]
#174
It comes in a spray can you just spray all the parts down to clean all the old grease off [sm=shades_smile.gif]
#175
TN
No need to wipe down dry afterward? And can I use just any ol' brake cleaner? Lastly, anything I should avoidgetting it on?
ORIGINAL: bigwaltc
