Brake cleaner is safe on the diffs? Any brand or type you recommend? I'm guessing just pore it in and wipe it down until its dry... correct?
ORIGINAL: bigwaltc
ORIGINAL: Allgood_73
Ok, now I can vision it much better, thanks for the explanation. So grease on both the bevel and pinion, and OFNA oil on the spider gears... got it.
Do you recommend 50 or 120k on the spider gears?
Do you recommend 30 or 100k on the bevel and pinion gears?
Lastly, If I put both grease and silicone in thedifferential case, it seems like they would splash and mix in together when the gears are all turning... correct?
Sorry for all the question, I just can't find a video on youtube for this or any good tuts.
No you should not mix them open it up clean it with brake clean then put your oil in it [sm=shades_smile.gif]
