Reinstall
FL
Reinstall
Hi,
I have just purchased a new computer and would like to reinstall Aerofly Pro Deluxe. Do I need to install my original Aerofly and go thru each upgrade? Where is the data file located so I can copy settings?
Also purchaseing Aerofly 5.
Ken Sawyer
Ken Sawyer
Moderator
My Feedback: (58)
RE: Reinstall
Ken, I have a few questions:
- Do you have AFP or AFPD?
- Which addons do you have?
If you want to save your current settings, backup the "config" file which you can find in the main directory, then copy it back to the directory after the re-installation
If you're getting AF5, just be aware that you can get the upgrade version from AFPD to AF5. Ensure that your computer system (PC or Mac) meets the system and video card requirements here http://www.aerofly.com/requirements_en.html
FL
RE: Reinstall
Hi Mike,
Now the fun starts. I'm running Win 7 Pro 64 bit with Nvidia 9800GT, 1 GB, video card.
AFPD runs fine up to V1.9.13. As soon as I install AddOn 5 or patch 1.11.07.21 it will not run. I had both these installed on my old machine.
It keeps asking for Open GL 2 or higher. I went to Nvidia site and downloaded latest driver which they say supports Open GL. Still will not work. Any help would be greatly appreciated.
Ken
Ken
Moderator
My Feedback: (58)
RE: Reinstall
Hi Ken,
1) Tell me exactly what kind of hardware you have, especially 3D graphics card, CPU, and any other hardware installed, sound card etc.
2) What is the RAM size?
3) Which operating system are you using, XP or Vista? 32 bit or 64 bit?
4) Tell me exactly what drivers you installed for the 3D graphics card.
5) Which addons do you have?
6) What is the version number printed on your main AFPD disk?
7) How did you install the main disk, addons, and patch (which version?), and what was the sequence of installation?
8) Post the tm.log file which you can find in the AFPD directory
You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your post.
FL
RE: Reinstall
Mike,
I have,
Intel i3, 8gb Ram, 1TB Harddrive
Windows 7 Pro 64 bit
Nvidia GeForce 9800 GT with 1GB Ram, Driver 8.17.12.6099
SoundBlaster Audigy
AFPD,
Original 1.8.0.25
AddOn 1 1.9.1.3
Patch 1.9.7.11
I installed the above in that order and every thing works.
AddOn 5, Patch 1.11.07.21 cannot get to work.
Tm.log Attached
tm: Library Version 4.3, Copyright (C) 1999-2006, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 9987814
tmsystem: cpu type=(nlogical=1) (nphysical=4) (no hyper-threading)
tmsystem: cpu=0 Mhz
tmsystem: memory=(physical=1023MB, avail=1023MB) (virtual=2047MB, avail=1674MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.9.7.11, Copyright © 1998-2007 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
tmgl: failed to load texture texture/cockpitmain.bmp
afdesign: init ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=1920x1080) (screen=1920x1080) (32bpp) (60Hz) (fullscreen)
directsound: init=(speakerconfig=unknown) (cont.rate) (primary 16bit) (samplerates 100,200000) (1 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce 9800 GT/PCI/SSE2, version=3.3.0, opengl version=3.3
gl: (viewport=8192x8192) (texturesize=8192) (stencil=8)
gl: extensions=GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl: extensions=WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NVX_DX_interop WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
gl: reducing max texture size from 8192 to 2048
tmsystem: fullscreen modes=(rj-640x480x32x60) (rj-640x480x32x60) (rj-640x480x32x60) (rj-640x480x32x59) (rj-640x480x32x59) (rj-640x480x32x59) (rj-640x480x32x72) (rj-640x480x32x75) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x480x32x59) (rj-720x480x32x59) (rj-720x480x32x59) (rj-720x480x32x56) (rj-720x480x32x56) (rj-720x480x32x56) (rj-720x480x32x72) (rj-720x480x32x72) (rj-720x480x32x72) (rj-720x480x32x75) (rj-720x480x32x75) (rj-720x480x32x75) (rj-720x576x32x60) (rj-720x576x32x60) (rj-720x576x32x60) (rj-720x576x32x59) (rj-720x576x32x59) (rj-720x576x32x59) (rj-720x576x32x56) (rj-720x576x32x56) (rj-720x576x32x56) (rj-720x576x32x72) (rj-720x576x32x72) (rj-720x576x32x72) (rj-720x576x32x75) (rj-720x576x32x75) (rj-720x576x32x75) (800x600x32x60) (rj-800x600x32x72) (rj-800x600x32x75) (1024x768x32x60) (rj-1024x768x32x70) (rj-1024x768x32x75) (1152x864x32x60) (rj-1152x864x32x75) (1280x720x32x60) (1280x768x32x60) (1280x800x32x60) (1280x960x32x60) (1280x1024x32x60) (rj-1280x1024x32x75) (1360x768x32x60) (1440x900x32x60) (1600x900x32x60) (1600x1024x32x60) (1680x1050x32x60) (1920x1080x32x60) (rj-640x480x16x60) (rj-640x480x16x60) (rj-640x480x16x60) (rj-640x480x16x59) (rj-640x480x16x59) (rj-640x480x16x59) (rj-640x480x16x72) (rj-640x480x16x75) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x480x16x59) (rj-720x480x16x59) (rj-720x480x16x59) (rj-720x480x16x56) (rj-720x480x16x56) (rj-720x480x16x56) (rj-720x480x16x72) (rj-720x480x16x72) (rj-720x480x16x72) (rj-720x480x16x75) (rj-720x480x16x75) (rj-720x480x16x75) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x16x59) (rj-720x576x16x59) (rj-720x576x16x59) (rj-720x576x16x56) (rj-720x576x16x56) (rj-720x576x16x56) (rj-720x576x16x72) (rj-720x576x16x72) (rj-720x576x16x72) (rj-720x576x16x75) (rj-720x576x16x75) (rj-720x576x16x75) (rj-800x600x16x72) (rj-800x600x16x75) (rj-1024x768x16x70) (rj-1024x768x16x75) (rj-1152x864x16x75) (rj-1280x1024x16x75)
directinput: searching joysticks=none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=radiointerface
tmsystem: searching usb interface (1) 1=unable to open interface device
tmsystem: searching usb interface (0) 1=unable to open joystick device
tmsystem: searching usb interface (1) 1=unable to open joystick device
tminput: 1 devices found
tminput: searching for input devices...(2)
tmsystem: searching dummy usb interface (0) 1=dummy radiointerface
tmsystem: searching dummy usb interface (0) 2=unable to open joystick device
tminput: checking for joystick 0=fail
tminput: 2 devices found
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params(3)=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=25729 mus
tmcollision: 1604 triangles using 205312 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6) octmin=(100.0,100.0,100.0)
tmcollision: otnodes=61 otendnodes=31 otdepth=14 otlistareas=23746
tmcollision: otnmaxareas=370 otnavgareas=67 otnminsize=(78.125,78.125,61.766)
tmcollision: otareas=2088 mem=213664
tmcollision: 61 octrees, using 9272 bytes
tmcollision: total mem=222936 bytes
tmcollision: time=0.01s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 extra330s...
(command file convert = 3) tmdairfoil: loading naca0015 ok
directsound: register sound sound/extra330s-1710.wav=ok
directsound: register sound sound/extra330s-3510.wav=ok
directsound: register sound sound/extra330s-5730.wav=ok
generating shadow extra330sshadow0=radius=2.98 bbmin=(-1.65 -1.65 -0.53) bbmax=(1.65 1.65 0.49)
sim: creating blurr=Propeller
loading input device calibration config/radio0.tmc=ok
loading input device calibration config/dradio0.tmc=ok
tmmusic: off
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=11754) -36 4) 88 (7E73320C)
directsound: shutdown
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
Ken
I have,
SoundBlaster Audigy
AFPD,
Original 1.8.0.25
AddOn 1 1.9.1.3
Patch 1.9.7.11
Tm.log Attached
tmsystem: cpu=0 Mhz
afdesign: init ok
init pixelformat=ok
tmmusic: off
Ken
Moderator
My Feedback: (58)
RE: Reinstall
Did you get any error message? Pls let me know the version number printed on your Addon 5 disk. During the installation of Addon 5, did you activate it using the key on the disk? From your tmlog file, it appears that Addon 5 and the latest patch were not installed. Did you install to the correct AFPD directory?
FL
RE: Reinstall
Hi Mike,
Been super busy plus internet was down couple of days. I got AddOn 5 to install. The key was installing everything in proper version order.
However I still cannot get the latest patch, 1.11.07.21, to install. I get several error messages which I will list below.
I have received my AeroFly 5. Will this install over AFPD or will it install in a new directory ?
Error messages- Could not install.
afpd language\language\1.tmd
" " \2.tmd
" " \3.tmd
" " \4.tmd
afprod.exe
aircraft\dc3\dc3.tgo
dc3.tmd
dc3.tmg
aircraft\eta\eta.tmd
" \139\139.tmd
\flyrun.exe
\OpenAL32.dll
scenery\ikarus.geo
" \rottenburg.geo
" \rottenburg.tgo
" \sparlingfield.geo
texture\aerofly.tmt
After stepping thru all of these it says sucessfully installed, but it does not update.
Ken
" " \2.tmd
" " \3.tmd
" " \4.tmd
afprod.exe
dc3.tmd
dc3.tmg
" \139\139.tmd
\flyrun.exe
\OpenAL32.dll
scenery\ikarus.geo
" \rottenburg.geo
" \rottenburg.tgo
texture\aerofly.tmt
Ken
