Aerofly
I just up graded to windows 10 now aerofly doesn't work, what happened
Please attach your tm.log file which you can find in c:\users\your username\My Documents\aerofly RC 7
I uninstalled it and trying to reinstall, but this error message keeps popping up (an error occurred while copying a file:Data error (cyclic redundancy check)
Please clean your DVD and try again. This error is normally caused by a dirty disk or a bad disk
Ok that seemed to work, is it not compatiable with windows 10, I had to go back to windows 8
It is compatible with win 10. I am running mine in win 10. It is better that you uninstall completely and do a fresh install of RC7 in win 10. If you have any activation error in win 10, let me know.
I redownloaded to windows 10 and asked to put in product key when I did it says its already registered
Hi Randy, I received your product key. Let me check it and I will get back to you.
Error code
Im getting error code 60000 when I put product key in
In case of error 60000 in aeroflyRC7, please follow the instructions here https://www.ikarus.net/en/fehlercode-10019-60000/
I followed the instructions and still get the same error code
What is the version number of your RC7? You can check this under the menu Help->About RC7
7.0.3
offline activation doesn't do anything
So what are my options, if I don't play it for awhile I have to keep putting in the code, now I keep getting the 60000 error code
Your RC7 version is 7.0.3 and you will need to perform the free update to version 7.5.9 first.
Please install the free update to V 7.5.9 from here at first: https://www.ikarus.net/en/rc7-updates/ After that please retry to activate the aeroflyRC directly via the main menu “Help -> Activate aerofly” If the activation still doesn`t work please use this browser activation dialog. https://www.ikarus.net/license/activate.php General note: By this way you create a license file by entering the product key and the serial number. The serial number can be found in the aeroflyRC main menu under “Help -> Activate aerofly”. You can simply move or copy the created license file into the user folder. All details are shown on the linked page. |
Says product key already registered, wont except the product key I have
Can you tell me the exact error code and message?
Error (60224) This product key has already been registered
Now what do I do
This browser link does absolutely nothing |
can I get another product key
Please PM me your current product key, full name, and address. I'll get you a new key.
I sent you the product key I have in a PM
Randy Forbus 50 Juniper Trail Ocala Fl, 34480 |
