JC P-100 RX flameout after a few runs
My Feedback: (18)
Hello,
I have a P100-RX which will run pretty well for 1 to 3 flights, then it starts to fail to startup or won't ramp up cleanly.
Two different symptoms, probably related:
Things we have tried w/mixed results:
I'm now losing confidence in the setup which we all hate, I'm on the verge of grounding the plane at this point, any help would be appreciated.
Regards.
- It will start, Stabilize and learn low. When you try to increase the throttle it will hesitate and ultimately die with a "LowRPM" off code.
- It will start and begin to ramp up but it will flame out while at "Stabil". Off code is "LowRPM"
- Checked fuel system, looks ok.
- Restart with GSU in manual and manually run up the throttle slowly until we reach full. (appears to work but I'm not 100% confident, symptoms have reemerged)
- Restart and relearn RC. (appeared to have worked once when it was dying, but then it didn't work when we tried it on an other day when it was dying.
- Set IdleThrResponse to : SLOW & set FullThrResponse to : Normal. (Also appeared to have worked and ran great for 4-5 runs. On the next trip to the field the symptoms reemerged. It's been really really hot and humid, I was advised this helps. It helped kind of, but not really.
Regards.
Try another pump.
if none available disconnect the turbine, put the tube in a ground tank and manually run the pump in test functions, run in stages, 1-2-3v hold at full/max voltage for 1 minute, run down in stages to 0.5v, then back up. Do that twice and try to run the turbine. It might clear the brushes.
My Feedback: (18)
Try another pump.
I tried what you suggested, and so far the turbine is running well, fingers crossed, thank you for the help! Great support.
sc
