JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Not sure on JR/Spektrum compatibility
Old 01-20-2017, 04:47 PM
Dig it
Dig it's Avatar
Default Not sure on JR/Spektrum compatibility
I've always used JR Rx's with my JR 12X DSM radio.
I need a 9ch Rx and can't find one but there are spektrum ones available. Specifically the AR9030T.
If I'm correct they will be compatible but I'd just like some input.
Dale
Old 01-21-2017, 11:40 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
As long as it's a Spektrum rx, you should be fine. Just look for either DSM2 or DSMX for the transmission/radio protocol.
Old 01-23-2017, 07:53 PM
Dig it
Dig it's Avatar
Thanks.
Dale
Old 01-24-2017, 11:01 AM
ColinW
Hi Dale - I'd check that as I think JR only do DSM2. Spectrum went onto DSMX but JR didn't follow. Any Spectrum DSM 2 will be OK.
Old 01-24-2017, 02:19 PM
fizzwater2
My Feedback: (61)
the DSMX receivers I have will bind/operate in DSM2 mode if that's what the transmitter does.
BigBirdFlyer (04-11-2024)
Old 01-24-2017, 07:24 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
How does this kind of misinformation get out?
DSM2 and DSMX are cross compatible, the ONLY caveat is that you cannot mix the components. If it's a DSMX main rx, it MUST have DSMX remotes/satellites. If it's a DSM2 unit, then it MUST have DSM2 remotes/satellites.
DSMX will run a bit faster but the Flight Logs are pretty much useless as there are so many fades with the DSMX channel hopping. The other thing is that the quick connect/power brownout indication is only available in the DSM2 format and the Flight Logs work quite well for those setups.
Old 01-24-2017, 08:28 PM
Jimmy Skids
Jimmy Skids's Avatar
The last generation of JR radios used DSMX, Horizon also was able to update some of the DSM2 JR transmitters to DSMX. I sent in my 9505 prior to switching to a newer JR DMSS transmitter and receivers.
Old 01-25-2017, 01:30 AM
AWorrest
The JR 12X originally was DSM/DSM2. These original ones could be updated to DSM2/DSMX as are the later ones. The DSMX capable transmitters have the DSMX logo on the screen lens. If the 12X radio is a module version, the screen may or may not have the DSMX logo as only the module had to be sent back for the conversion.
Allan
Old 01-25-2017, 10:37 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Allan
There is also a small half "X" on the right side of the top center label plate of the converted DSMX 12X transmitters.
Old 01-31-2017, 06:00 AM
SAB
Zeeb says "How does this kind of misinformation get out?"
One reason is that in the US you could get a DMSX version of the JR 12X or get HH to update a DSM2 version to DSMX. However for all of Europe and majority of the rest of the world DSM2 (and DSMJ for Japan) was all you could get. So the post by ColinW is from a European (UK) perspective where the 12X was only ever DSM2 & all the JR DSM receivers were only ever DSM2. Yes I understand a DSMX receiver is backward compatible with DSM2, however, from the European/UK perspective a user wishing to buy only JR receivers DSM2 was the only option and may therefore never have been aware of the DSM2/DSMX backwards compatibility.
Steve
Old 02-21-2023, 11:36 AM
RC 3D
Default Jr incomparable with newer spektrum receivers
Old thread
Update on Jr and Spektrum compatibility
There is a problem with the newer Spektrum Receivers that are dsm2 compatible due to their hardware change, with the ti chip making them incompatible with Jr legacy transmitters.
Older Spektrum Receivers are okay.Jr transmitters will often losing binding.
Newer DSM2 compatible receivers are not compatible with older legacy transmitters do to changes in the hardware. Crashes reported besides loss of bind.
Older receivers worked fine with jr.
8+channel old modules (DM8, DM9, JR 9303) are not compatible with spektrum newer receivers. Even if they appear to work.
All newer spektrum receivers are TI-based and also includes E-flite BNFs.
AR410 and AR620 included
