Where to mount my KingTech 210 in a Skymaster Hawk
What is the distance from the K210 to the pipe when I mount it in my Hawk? There are no guidelines in the KingTech manual. Are there some basic guidelines or formulas to calculate where the turbine should sit relative to the pipe?
A good rule of thumb is not to have any part of the tailpipe closer than 20mm (3/4") from the exhaust of your turbine, but also not futher than 30mm (1 and 1/4") apart. So depending on the diameter of both, this will vary the distance of the pipe behind the turbine.
No need for the thumbs down & you may want to read the manual again. The K210 distance of 20-30mm has been in the manual for years now. I have been using 1"/25mm on a few K210's with no issues. See Kingtech info below along with JetCat's detailed pipe size and distance guidelines.
G manual page 44 www.kingtechturbines.com/doc/manual.pdf
G2 manual page 76 www.kingtechturbines.com/doc/Manual_G2.pdf
