Want to build my first kit
RE: Want to build my first kit
ORIGINAL: Spridal
acdii,
How well does the 4*120 hold up to the DLE20? What type of covering did you use? I'm really leaning towards the 4*120 since Ialready have the DLE20 but wanted to make sure there wouldn't be any issues.
ORIGINAL: acdii
the DLE would shake a 4*60 apart unless you really build it tight and reinforce it well. I fly a 4*120 ARF with the DLE20 and it is adequate power, not a knock your socks off rocket ship, but it performs nicely.
As far as a good first kit, Excellent choice. SIG makes really good kits, and the 4* is one of them. I built a Kadet LT40 and modified the wing to a bolt down, with a 2 degree dihedral, which is about 1", and converted to tail dragger, and it flies great, love the plane and it went together fast and clean. The 4* is a blast to fly, I flip it spin it, toss it around the sky, fly inverted, snap rolls, and take out corn stalks with it. A really fun plane.
My 4 strokes vibrate more than the DLE does now, so it will hold up quite well. Mount your tank over the CG, make a cover for the nose so you can get in there to mount the ignition module. I'll see if I can get some pics of my setup before Iput the cover back on.
My Feedback: (-1)
ORIGINAL: prgonzalez
Gene,
YOU ARE SO BLESSED!!!
Pedro
ORIGINAL: Gray Beard
... Kidding aside, at a club auction I picked up the Royal F4U Corsair Giant scale with spun aluminum cowl for $10.00. the CG Extra for $10.00, Super Sky Bolt for $10.00 and a couple of 40 size kits for $10.00. I was the only builder left in that club and I picked them all up for my opening bid. ....
Pedro
Spridal, the 4* 120 was once a kit and not too long ago, sorry, I have no templates for it but if you look in our market place you may find a kit? The kit is a bunch stronger then the ARF and would be a bunch better with the DLE engine. If you look in acdii's thread you will find a couple others that have the ARF and they are being stressed with the DLE.
There are just so many other 120 kits/planes that would be better for the little gas engine. Although not a fire breather it will stress a light weight ARF. I have a 60 size CG Extra that has been flying sense 1989 with a YS 1.20 20cc four stroke, almost no vibration compared to the DLE. My point is if you build a kit or from plans a bit of over power isn't going to hurt the air frame.
Arfs are fine but very light weight, look around for a kit.
My Feedback: (17)
Gray Beard,
http://www.sigmfg.com/IndexText/SIGRC65.html
My intentions were to build from a kit and I believe the kit is still available.
Ihave some pics. GB is correct, the ARF is stuck together with hot glue. Idoes need beefing up in places, which Idid tonight with some 30 minute with milled glass spread across the joints and hit with the heat gun until it flowed like water. Should be plenty strong now. Irepaired the wood where it got busted, and cut a hatch opening in the front. Waiting for the glue to dry so Ican fit the hatch and secure it, then will recover it.
#31
My Feedback: (-1)
ORIGINAL: Spridal
Gray Beard,
Gray Beard,
The 120 was an outstanding kit and fun to bash.
#32
According to the site you can order it. Tempted to order a 60 myself. The ARF's are no longer made, so if you can find one, grab it. I know where I can get 2 40's one in each color, but too small for me. Although, It would be small enough to fly at my house.
#34
My Feedback: (17)
Ok,
I think I've decided on the Contender. Ialmost pulled the trigger on the SIG, but after several failed attempts to reach them, itleft me feeling very uneasy. With that said, I would like to hear suggestions on engines. The manual calls for a 46 but I'mnot sure if that will give the plane enough kick. If any of you have flown this plane please let me know if the 46 will give the plane some spirit.
#35
Spridal,
Good selection on the Contender.
But wait, there are other models you can also take a look, the Great Plane Dazzler and Tower Hobbies Uproar (Pretty much same airplane). They are easy to build, very fun to fly and can be built in about two weekends. But the Contender is really a good choice.
The overall performance of engine, airplane, and prop depends on how straight and light you build the model. Besides wood itself, the mayor culprits for weight are adhesives (CA, Epoxy, Wood Glue), electronics, and hardware. The Contender with an estimated weight of 6 to 6.5 lbs, I would go with the high end engine, a 0.52 to 0.61 2-strokes or 0.70 4-strokes. BTW, I have a Dazzler and its final weight is 5 lbs and with a 0.46 w/11x5 APC prop has unlimited vertical. In servos, you can save one easy OZ by using a micro or mini servo for throttle. Another easy OZ is in the tires. Go easy on the epoxy and CA.
my 2 cents,
Pedro
my 2 cents,
Pedro
#36
My Feedback: (17)
Thanks Pedro,
I took a look at the Dazzler and Uproar but for some reason the Contender stood out. Thanks on the engine suggestions. I think I will go with the OS 55ax or the Saito 82, which from what I understand is close in dimensions and weight as a .70 4-stroke.
#37
My Feedback: (-1)
The contender I know nothing about but when I was into fun fly events I used the Up-Roar 40 or the Dazzler. For competing in fun flys i used nothing except the .46 LA engines and it was about a perfect combo. Both planes would handle the .55 AX but they really don't require that added power. I once used a Roar to break in a .58 MDS and all I can say is WOW!!! Really added a bunch more zip, un-needed but the plane could handle it. Not sure for how long though. Any of the fun fly type of planes are very easy to build. Fun fly events meant your plane was expendable so they were designed to be built in about 12 hours as needed.
#38
My Feedback: (17)
Ok Guys,
I pulled the trigger and went with the Contender. It should arrive on Wednesday if they ship tomorrow. Now all I need isa building board and I'm good to go.
#42
Perhaps you can also consider the Top Flite Contender.
Pedro
Pedro
+1 on the contender!!!!!
I think you would be happy with the end product, no matter how advanced you get as a pilot, they are still fun to fly... They build easy and fly like a dream.....
Jimbo
#44
My Feedback: (17)
Hi Guys,
Just a quick update. I started the Contender builda few days ago and I now have the wing, rudder, stab, elevators and ailerons built. I plan to have the fuse complete in about a week or so then I will begin sanding. I must say it has been rewarding seeing a box of wood start to take form and become something that resembles and airplane. I will keep everyone updated as I progress. Thanks to all again for your help and encouragement.
#45
My Feedback: (17)
Ok Guys,
I'm back with another question. After sanding the airframe will I need to add some type of sealant or prep the wood before applying the Ultracote?
#46
IL
It all depends your desired finish. Like painting, a covering job will only be as good as the prep work that went into it. Gaps, excessive glue, uneven, nonflush surfaces are often amplified by the covering. Dents and nicks, from moving the model around, or bumping tools into it will show, as well as fingernail marks in the soft balsa.
I usually use a spackle type compound and fill in the noticeable defects, then go around and sand everything. I sand 150, 220 and 400 grit and use tackcloth. Afterwards keep your work surface nice and clean. Tools laying around and whatever else is on your building board will easily dent the nicely finished balsa....so be careful handling before and during covering.
The ultracote goes on the bare wood...no need to seal anything except the firewall area and fuel tank area.
#47
My Feedback: (17)
ORIGINAL: ArcticCatRider
#49
My Feedback: (17)
Thanks for the tip. I completed the fuselage about two hours ago. I hope to test fit everything and then sand within the next week or so. Thanks to everyone for helping me get this far.
#50
My Feedback: (-1)
Everything artic cat said. I use Ultra as my main covering. After finish sanding I use a compressor to blow off the plane then I use a bristle paint brush. Last but not least I use a tack cloth to make sure all the dust is removed. For 99 cents a piece a tack cloth is nice to have in your shop. Covering sticks very well over just wood with nothing brushed or sprayed on. Even using lacquer hair spray over the wood makes it adhere better but if you need to remove it for repairs it can be hard to get off again! I have a repair to do now but I can't get the old covering off. It was built in the late 80s and the builder used balsarite on the wood. Even using an iron and heat gun doesn't help lift it! Only time to use anything on the wood is if it has had oil on it from your fuel.
