Reload this Page >
Charge port/power switch locations
Old 07-30-2013, 06:57 PM
p3arljam
Default Charge port/power switch locations
If anyone has any pictures of there planes or build showing where they put there charge port and power switches can you post some pictures. Im trying to find a way so i can hide them.
Old 07-31-2013, 05:23 AM
skyhawkjock
Default RE: Charge port/power switch locations
Put them inside a hatch, or in the cockpit of open cockpit models large enough to hide them. Another option is not to mount the charge receptical on the outside of the plane. Remove the wing to get to it. Disguise the power switch by mounting it inside the plane, and activating it with a stiff music wire that looks like an antenna or other normal object such as a pitot tube, OAT probe or angle of attack probe.
Old 07-31-2013, 06:49 AM
Edwin
Depends on the plane. A bigger plane would get a hatch or cockpit location. Smaller .60 sized usually have some black on them someplace so I put it there. Trainers just get it on the side.
Edwin
Old 07-31-2013, 10:15 AM
FlyerInOKC
FlyerInOKC's Avatar
I built a SIG J-3 Cub which has an opening door so I put the switch, charging port, and remote glowplug connection inside out of sight. The Cessna 182 I am currently building will have a working luggage door with the switches, etc inside. It will have a cockpit kit installed and it will modified to appear and aux fuel tank was mounted in the baggage area (common aftermarket item) that will hide the switch mountings.
Old 08-01-2013, 05:16 AM
ortmayerm
Which 182 kit are you building?
Old 08-01-2013, 05:36 AM
FlyerInOKC
FlyerInOKC's Avatar
I'm building the Top Flite kit. I was touching up the carving of the Hoerner wingtips and laying out the nav light positions on it last night.
Old 08-01-2013, 05:41 AM
FlyerInOKC
FlyerInOKC's Avatar
My next build will be the avitar at the left.
Old 08-01-2013, 10:41 AM
VincentJ
VincentJ's Avatar
Here's where I put mine. It will be covered by the pilots bust that will go over it.
Old 08-01-2013, 10:49 AM
FlyerInOKC
FlyerInOKC's Avatar
Great idea! I will have to try that on my next open cockpit airplane.
