Giant Astro Hog Laser Cut Kit - Jerry Bates
#226
My Feedback: (29)
One thing to remember about electric power is that they deliver instant torque. That’s one reason that it’s typical to use more right thrust. Another reason is that we commonly use more pitch. Taking into consideration your Avian motor specifications, my suggestion would be an APC 21.5x13.5 carbon prop and use a 10S battery. I would set the motor to 3.5 degrees right thrust and .5 degree down thrust. If wet powered with a 13.5 pitch prop you would be correct to think that landing speed would increase, with electric power you can use the ESC brake function to slow the airplane down.
#227
Hello,
it's hard to say because I can't try it out. But I wouldn't add more than 3 degrees. If it's not enough you can mix a little rudder onto the throttle servo. That works well. I have programmed my transmitter so that the rudder deflects about 3 mm at full throttle (with 2.5 degrees of right thrust).
#228
