4*60 color schemes
#58
covering job
mstroh3961: Did you glue the tail to the fuse before covering? Cause the instructions say to do it seperatly.. and i'm wondering what way is better...
-eugn
-eugn
#59
IN
4*60 color schemes
Here's a picture of mine. I just modified the ailerons, elevators and rudder on it. It was metallic teal blue and neon pink before. Couldn't see it before with that scheme, but I can see it now real good.
Jon
Modified 4*60
Jon
Modified 4*60
#60
CO
Re: covering job
-eugn
-eugn
I changed the picture in the post above to one of the fuselage's covered !
#62
Re: One More Inside Shot
RSprinkel: how did you tint your canopy? if you used some product, can you please tell me it's name and where i can get it?
thanks
-eugn
thanks
-eugn
#63
Re: Re: One More Inside Shot
thanks
-eugn
thanks
-eugn
Have fun!!
#65
CO
cowl
*Crash*Johnson*
This cowl is from FiberglassSpecialtys.com It fits the .60 size Four Star's. Price is around $37.00 plus shipping. Only down side is mounting the engine inverted. The cowl slides so far onto the fuse, that side mounting becomes impossible unless the cowl is split in half (upper/Lower). On the plus side it looks cool!
MStroh, what cowl is that from? Also, is that a 40 or 60 plane?
#66
RE: The finishing toutch
If doing a color scheme like this one did you first put on the lighter color and then put the darker one directly on top of the lighter color...?[sm=confused.gif]
#67
In short, yes. Is this your first covering job ? I found the following useful - books by Higley and Faye Stilley, Top Flite's Monokote video, RCU threads on applying trims using windex (do a search), and various building articles like http://members.shaw.ca/nsrcawestdistrict/enigma.htm
#68
QC, CANADA
Here's mine. I went kinda crazy one year, after learingin about the 'glass method' for joining sheets of monokote together.. hence why a lo0t of my planes have 'wavy lines' where one colour changes to another..
