Sig 1/4scale C/W Cub build
#2127
My Feedback: (48)
RE: Sig 1/4scale C/W Cub build
Hello all,
If you haven’t seen Cub Mans posts (post 608) on the Cub Brotherhood forum have a look. http://www.rcuniverse.com/forum/m_10...25/key_/tm.htm
If you have benefited by his website perhaps a little assistances would be in line about now.
#2129
Changing the subject back to... well... the subject... VJ, have you considered what engine you will be using to replace the DLE20? I would really like to see one that will fit "under the hood". So, any ideas?
Take care,
David
Take care,
David
#2130
My Feedback: (50)
I have a Evolution G26 Gas burner under the hood on my L-4. The plane is around 17 pounds. Power is great I can fly it scale but also has a little extra power to use if needed. This fits total under the hood except for the plug. Now for the issues I have. The carb sets in front of the engine like a glow. It is the standard big carb as most gas engines. This blocks what little air that comes thru the holes in the front of the cowl. With that said this runs hot when it is coweled in. with this said, I have just built from 1/64 ply a shroud from the side and have a small pc fan mounted to blow air across the head. This is a 5 v fan so it will run off of my 4 cell ignition pack. I have yet to give it a try, hope to try it this weekend due to a event at our filed next weekend.
#2131
David, I have been looking at the DLE30 for a possible fit of course that is going to mean some firewall movement . Oh well just more work. I haven't repaired the wing tip yet. Going to tackle it this winter. Right now I have a new build on my table (Sig Ryan STA) which has really gotten me out of my funk so to speak. Here is the thread if your interested in checking it outhttp://www.rcuniverse.com/forum/m_11208903/tm.htm
#2132
CubMan..... What tires do you have on the Cub you just posted a photo of? They look like 1/4 Cub tires and they look like they may be air filled / soft.
SunDevilPilot
#2133
My Feedback: (50)
SunDevilPilot they are a set of the good old dubro cub wheels. They are air filled. yes I have to pump them up a couple times a year but love then 10 time better then the foam version. `Keep an eye out on ebay for them. Wish dubro would bring them back!!!!!!!!!!
#2134
ORIGINAL: Cub Man
I have a set of 6" Dubro "balloon" tires that Dubro renamed "Tundra Tires". I was having ground handling problems with them on so I removed them and installed the stock foam Dubro 1/4 Cub tires. The handling problem was corrected but they are foam and wear rather quickly doing long touch-n-goes on asphalt.
Thanks for the info!
SunDevilPilot
#2135
LA
ORIGINAL: Cub Man
#2136
I had Dubro foam filled tires on my 1/4 Cub and they did fine but I was always flying from grass. I also have them on my 1/3 Cub.
I have my planes loaded in the trailer and I will be spending the day at the field. I haven't flown the 1/3 Cub for about 2 months, time to get some air under it wings.
Later!!
Anthony
Later!!
Anthony
#2137
ORIGINAL: RC_AVIGATOR
Off the subject, what prop nut assembly is that in this picture?
ORIGINAL: Cub Man
http://www.sierragiant.com/prod43.html
SunDevilPilot
#2138
ORIGINAL: VincentJ
Now all I need is some money....... DOH!!!!
#2139
My Feedback: (36)
SunDevilPilot, Dubro still sells the J-3 Cub air up valve treaded tires/wheels/cub hub cap. You will have to call them direct as they cannot advertise them or sell through a dealer because goodyear had a dispute with them over putting the goodyear name on the tire. I bought a set some time back by calling them about a set. I just bought a set on ebay a couple of months back for my H9 J-3. They work so much better on landings to soften it out along with the bungee gear.
Eddie
Eddie
#2140
ORIGINAL: cannonball200
Eddie
Eddie
SunDevilPilot
#2141
My Feedback: (50)
RC_AVIGATOR Take a look at http://www.vaillyaviation.com/Intro.html they have a 1/5 scale prop nut that I used. Had to do a little work to it, but was able the thread the hole int he center and just screw it on the motor shaft.
#2143
Did Dubro have the cub air-up tires still?
Eddie
Eddie
I'll let ya know.
SunDevilPilot
#2144
My Feedback: (36)
SunDevilPilot, I called Dubro about the 1/4 cub air-up tires/wheels/hub caps set. He said they had a few sets left and when they are gone thats it- no more. He said there was no dispute with Goodyear on that product, they just started making the foam products which are lighter which he said everyone wants lighter.
He said the pricing would be the same as the 1/4 foam set.
Eddie
Eddie
#2145
Eddie
Eddie
SunDevilPilot
#2147
I just finished up a prototype set of bungee covers for my Sig 1/5th Scale Cub. I would like to find some vinyl type material when I make a set for my 1/4 Cub.
The covers slip over the bungees then the ends are cinched down with small zip Ties. The zip ties can be replaced when the bungees need servicing. The o-rings and rubber bands really take a beating when they are fully exposed.
The covers are wide enough to allow for the movement of the bungees as the bumps are absorbed by the gear.
Once I make some for my 1/4 Cub, and determine the dimensions, I will make some extra for you guys with the Robart Gear.
SunDevilPilot
SunDevilPilot
#2148
SDP,
I made a set for my 1/3 from Black Nylon. I do not have to worry about O-rings as my gear has springs so I used 1/16" elastic cord sewed into the ends to tie it to the gear legs. The nylon is flexible enough to give it a more scale look on the gear.
Later!!
Anthony
Later!!
Anthony
#2150
I called Dubro this morning. Very nice people!
I ordered two pair of the air filled Cub Tires.
Thanks again for the info on how to order them.
SunDevilPilot
