Pin Stripes!
Pin Stripes!
Several years ago my wife gave me some pin stipes to make my AC look "Prettier".
Today, I finally got around to using them .
A friend tells me that they are "Automotive" pin stripes - OK - as long as they work , who cares??
They are self adhesive, white, double stripes. I applied them with some light
pressure and they look pretty good.
But; they went on with a clear plastic coating holding the two stripes in place.
Should/Does the plastic come off?
Do the stripes stand up to the pressures of flight and fuel residue?
OR
Should I just apply a thin bead of CA to seal the stripes in place?
OR
My Feedback: (27)
WI
RE: Pin Stripes!
If they are automotive stripes, the clear plastic is just a carrier to insure that they are applied with constant space between the individual stripes. By all means remove the carrier. Afterwards, as long as the stripes are securely stuck, you shouldn't need to do anything. It isn't too likely that they will be abused any more on your plane than the would on a full size car (e.g. wind, car washes, salt, road grime, etc.)
MO
RE: Pin Stripes!
I have had issues of pinstripe not sticking in high oil residue areas, especially on canopies. Give it a try, the worst that could happen is that they fall off.
