NEED HELP TO I.D. THIS PLANE
TN
I was asked by a friend to finish this plane that was gave to them but I'm not sure what it is, or intended for. This plane has a 60.5 in. wing span, the fuselage is 40in. it is a top wing, it looks like a piper cub but it is a radial engine plane. This is a dummy cowl and was built for a small 2 stroke, it is a very old plane. This model has no ailerons, no elevator and as far as a rudder it is very small just 3 3/4 inches cut into the vertical stab almost like a trim tab. I havent ruled out control line, and have had many suggestions that it could be a free flight but this big and this heavy?? this plane also has carved wooden wheel pants and skerts and is a tail dragger, full windshield and side windows. did piper cub ever build a radial engine, this plane was built to fly ,BUT HOW nothing indicates this to be built as an r/c plane!!
My Feedback: (16)
RE: NEED HELP TO I.D. THIS PLANE
Appears to be a old single channel escapement job from the late 50's? There were a lot of them that size. The radial cowl doesn't ring any bells.
It could be a bashed kit with the radial cowl added?
Piper didn't make any radial powered planes but Cessna did.
It would take a lot of work to make this plane into a current day radio control model.
It is not a control line model.
Enjoy,
Jim
Enjoy,
Jim
