Hangar 9 Alpha 40 foolproofing needed?
My Feedback: (20)
VA
I posted this in the ARF/RTF section, but thought I may get additional response here as well...
I just bought a Hangar 9 Alpha 40 RTF. It came with the engine (.46 TPS) pre-installed.
Does anyone know whether the firewall area has been fuelproofed?
Should I remove the engine and beef up the firewall w/ triangle stock and fuelproof w/ epoxy?
Bob
Bob
My Feedback: (20)
VA
RE: Hangar 9 Alpha 40 foolproofing needed?
MinnFlyer,
Thank you for you reply.
I'm still trying to figure out which forum is the correct/best to post in....
I will follow your directive in the future.
Bob
Bob
ORIGINAL: AB Bob
VA
Bob,
I see you are just down the road from me. Where do you fly at?
I use thick CA and 30 min epoxy to fuel proof my planes.
Frank
Frank
BC, CANADA
I learned with an Alpha 40. I didn't need any extra fuel-proofing on mine, but I would recommend a little reinforcing on the firewall. It takes a bit of a beating, and needed a couple repairs.
I second the recommendation to reinforce the firewall with some tri-stock. Mine popped loose early in my training from an ugly landing that I think it should have been able to handle. Epoxy some tri-stock behind the firewall if you can get to it, or in front if it will fit. And while you have the epoxy mixed, I would fuel proof the engine bay as well.
Good luck
Good luck
