Reload this Page >
SIG Ryan STA special kit by Maxy Hester
Old 07-07-2016, 05:40 AM
  #226
jwharkinz
jwharkinz's Avatar
Originally Posted by FlyerInOKC
Thinking about your elevators I would lean toward building new ones with a core of thin balsa or ply and then stringers on both sides to give the appearance of stick built and a few blocks thrown into the hindge locations. Just my 2 cents.
Mike
After thinking about it and your post, it would be pretty negligent NOT to fab new elevators at this time. I am leaning toward hollow core built up elevators as used in modern plane builds, then adding stringers for appearance. That's today's agenda, now I can build in better options for remounting. Thanks. (2 cents accepted, rubs them together...)!
Old 07-07-2016, 06:21 AM
  #227
FlyerInOKC
FlyerInOKC's Avatar
Glade to help, I know I get a little tunnel vision on my own builds, it helps when you get a good suggestion before you go too far.
Old 07-09-2016, 02:37 PM
  #228
jwharkinz
jwharkinz's Avatar
Thus far I have completed part of the pair of elevators, and today I have been carefully MIG welding parts for this plane. What is going on here is an attempt to lock all the components of my new elevator tie/control rod together so as to be fastened with a single screw. One of the rod ends will be threaded to receive the fastener. The other will be pass thru, more filing to complete the fit is needed then drill and tap the hole.
ID:	2172059   Click image for larger version
ID:	2172060   Click image for larger version
ID:	2172061   Click image for larger version
ID:	2172062   Click image for larger version
ID:	2172063   Click image for larger version
ID:	2172064   Click image for larger version
ID:	2172065   Click image for larger version
ID:	2172067   Click image for larger version
ID:	2172068   Click image for larger version
ID:	2172069   Click image for larger version
ID:	2172070   Click image for larger version
ID:	2172071   Click image for larger version
ID:	2172072   Click image for larger version
ID:	2172073   Click image for larger version
ID:	2172075   Click image for larger version
ID:	2172076   Click image for larger version
ID:	2172077   Click image for larger version
ID:	2172078   Click image for larger version
ID:	2172079   Click image for larger version
ID:	2172080   Click image for larger version
ID:	2172081   Click image for larger version
ID:	2172083   Click image for larger version
ID:	2172084   Click image for larger version
ID:	2172085   Click image for larger version
ID:	2172086   Click image for larger version
ID:	2172087   Click image for larger version
Old 07-09-2016, 08:27 PM
  #229
haefeli
haefeli's Avatar
Instead of thread locker on my small bolts I use contact cement. Will not let screw loose fro vibration. Use it for mg zeros too.
Old 07-11-2016, 10:05 AM
  #230
FlyerInOKC
FlyerInOKC's Avatar
Impressive! You put a lot of work into that I can't wait to see it installed.
Old 07-11-2016, 01:58 PM
  #231
jwharkinz
jwharkinz's Avatar
So I had a FAIL. while attempting to drill, the bit skidded to the side when encountering the piano wire. Resulting in what the photo represents.
I went back and dug up some scrap material 1/4 inch steel plate. drilled the 1/8th holes for the wire and some 3/32 for the weld bead. The steel also helps to absorb the heat letting me turn up the amps to get better penetration in the weld, that damn wire is tough!! So I am where I left off yesterday. Let's hope tomorrow is better...
ID:	2172446   Click image for larger version
ID:	2172447   Click image for larger version
ID:	2172448   Click image for larger version
ID:	2172449   Click image for larger version
ID:	2172450   Click image for larger version
ID:	2172451   Click image for larger version
ID:	2172452   Click image for larger version
ID:	2172455   Click image for larger version
ID:	2172456   Click image for larger version
ID:	2172457   Click image for larger version
ID:	2172458   Click image for larger version
ID:	2172459   Click image for larger version
Old 07-12-2016, 07:55 AM
  #232
jwharkinz
jwharkinz's Avatar
Now for the install...
ID:	2172666   Click image for larger version
ID:	2172667   Click image for larger version
ID:	2172668   Click image for larger version
ID:	2172669   Click image for larger version
ID:	2172670   Click image for larger version
ID:	2172671   Click image for larger version
ID:	2172672   Click image for larger version
ID:	2172674   Click image for larger version
ID:	2172675   Click image for larger version
ID:	2172676   Click image for larger version
ID:	2172677   Click image for larger version
ID:	2172678   Click image for larger version
ID:	2172679   Click image for larger version
ID:	2172680   Click image for larger version
ID:	2172682   Click image for larger version
Old 07-12-2016, 07:56 AM
  #233
FlyerInOKC
FlyerInOKC's Avatar
You're one up on me I never get piano wire to drill correctly!
Old 07-13-2016, 01:47 PM
  #234
jwharkinz
jwharkinz's Avatar
I plan to have the tie rod go beyond the inner hinge on each side, this should add some stability having the rod further out from center...
ID:	2172829   Click image for larger version
ID:	2172830   Click image for larger version
ID:	2172831   Click image for larger version
ID:	2172832   Click image for larger version
ID:	2172833   Click image for larger version
ID:	2172834   Click image for larger version
ID:	2172835   Click image for larger version
ID:	2172837   Click image for larger version
ID:	2172838   Click image for larger version
ID:	2172839   Click image for larger version
ID:	2172840   Click image for larger version
Old 07-14-2016, 09:30 AM
  #235
FlyerInOKC
FlyerInOKC's Avatar
Bras hinges to boot this should last forever.
Old 07-15-2016, 10:25 AM
  #236
jwharkinz
jwharkinz's Avatar
Had a setback with the brass hinge idea. Have spent the day re-fabricating nylon hinges that can flex a little and take the vibration abuse. The brass was awesome looking but that **** broke while I was bending the 2nd rod. The nylon will probably last just as long.
ID:	2173033   Click image for larger version
ID:	2173034   Click image for larger version
ID:	2173035   Click image for larger version
ID:	2173036   Click image for larger version
ID:	2173037   Click image for larger version
ID:	2173038   Click image for larger version
ID:	2173039   Click image for larger version
ID:	2173041   Click image for larger version
ID:	2173042   Click image for larger version
ID:	2173043   Click image for larger version
ID:	2173044   Click image for larger version
Old 07-20-2016, 01:09 PM
  #237
jwharkinz
jwharkinz's Avatar
More photos...
ID:	2173753   Click image for larger version
ID:	2173754   Click image for larger version
ID:	2173755   Click image for larger version
ID:	2173756   Click image for larger version
ID:	2173757   Click image for larger version
ID:	2173758   Click image for larger version
ID:	2173759   Click image for larger version
ID:	2173761   Click image for larger version
ID:	2173762   Click image for larger version
ID:	2173763   Click image for larger version
ID:	2173764   Click image for larger version
ID:	2173765   Click image for larger version
ID:	2173766   Click image for larger version
ID:	2173767   Click image for larger version
ID:	2173769   Click image for larger version
ID:	2173770   Click image for larger version
Old 07-21-2016, 11:31 AM
  #238
thomasmuckus
thomasmuckus's Avatar
I love Your solid metal work. As additional for Your new elevator I suggest to work out the trimflaps > it will take not so many time but it looks great
by the way > red is added
ID:	2173858   Click image for larger version
Old 07-21-2016, 12:33 PM
  #239
FlyerInOKC
FlyerInOKC's Avatar
I like it!
Old 07-22-2016, 05:31 AM
  #240
jwharkinz
jwharkinz's Avatar
There it is!....
That is one SEXY airplane, I was considering adding in some details with the flitemetal. You're teasing me with the wonderful work displayed in your photos.
Old 07-22-2016, 08:51 AM
  #241
thomasmuckus
Sorry my friend, but I`m driven by one of my buddies. Everytime when he visited me he says, hey looks great but if You add this detail or this it will be even better.....
This ist the reason for my delay by maiden flight, normaly it should be in May. Now I`m glad when I can manage it at the end of August.
Old 07-23-2016, 07:13 AM
  #242
jwharkinz
jwharkinz's Avatar
Cramming to finish...
These photos show that the elevator is complete sans the cover and paint. The setup is ready and the upgrade was definitely worth the hassle and time.
I did get the smallest servos that were available, I didn't realize this until they arrived. Take note, You gets what you orders late at night, half awake, shopping for solutions to self made issues.
These are metal gear, just soo small. I do think that 40 oz.in of tq. should do at low throttle for flap operation. I plan to increase torque with small horn length. It's all good compared to the slop I had to deal with using linkage. This is a good example of insanity: I new better than to try a single servo and linkage, but I did it anyway thinking I could make it work this time! can u say FAIL?
The on-board glow will also take on another challenge. I ordered some adjustable voltage step-down regulators from the robot shop. I intend to eliminate the battery here and tap into the flight battery for power. So far it's like this: Main power for radio & servos, Brake operation, and On-board Glow from a single power source.
ID:	2174033   Click image for larger version
ID:	2174034   Click image for larger version
ID:	2174035   Click image for larger version
ID:	2174036   Click image for larger version
ID:	2174037   Click image for larger version
ID:	2174038   Click image for larger version
ID:	2174039   Click image for larger version
ID:	2174041   Click image for larger version
ID:	2174042   Click image for larger version
ID:	2174043   Click image for larger version
ID:	2174044   Click image for larger version
ID:	2174045   Click image for larger version
ID:	2174046   Click image for larger version
ID:	2174047   Click image for larger version
ID:	2174049   Click image for larger version
ID:	2174050   Click image for larger version
ID:	2174051   Click image for larger version
Old 07-23-2016, 07:42 AM
  #243
FlyerInOKC
FlyerInOKC's Avatar
What a gorgeous airplane!
  #244
haefeli
haefeli's Avatar
40 in. Ounce servos are fine for throttle, I'd go spend more money. Analog servos only can push as hard as pushed upon unlike digital. I wouldn't chance the servo issues.
Old 07-23-2016, 01:52 PM
  #245
foodstick
foodstick's Avatar
I am always surprised about how big the following is on this kit. It takes a lot of work to make this plane as nice as jwharkinz's !
If you want to hear a funny story about this kit... read below.
One time my buddy and I went to an estate sale.. he picked up a few planes... boxes of odd loose stuff, and I bought a garbage can full of plans. At the end of the sale they were telling people to just grab the odds and ends and take them home. Lots of things got left scattered around on tables. Well my buddy ended up with a half built kit and a bunch of parts but no idea what it was.. it was pretty boxy, and obviously and old school kit. A week or so later we went to another sale and there was that same airplane stuff for sale cheap.. and free again. this time my friend says,
"I think that fuse is for a Maxy Hester STA, I wish the whole kit was there."
Another two weeks go by and My friend and I dig thru the boxes of odds and ends, and my garbage can full of plans... Out comes a set of Plans for the STA. My friend takes them home and compares them to the unidentified kit parts ..sure enough.. the free fuse and parts we had kept avoiding for the last two sales were the OTHER HALF OF HIS KIT !
We never saw them again ! hahahahah
Old 07-25-2016, 05:42 AM
  #246
FlyerInOKC
FlyerInOKC's Avatar
Now that would hurt!
Old 07-28-2016, 10:23 AM
  #247
jwharkinz
jwharkinz's Avatar
Getting closer to completion
In a couple photos you can see where I swapped the battery for a voltage reducer regulator and the whole thing now weighs 1/2 oz. less than just the battery! Hope this works as well as it does on paper. The servos are fully programmable digital, and will be compatable with the radio as well. They're small but badass. With some smaller horn length I can get each one to around 48-50 oz. inch. That's more than the original plans had, I will keep an eye out for any issues here tho. Getting ready to finish the wheel pants in flitemetal. Then the polishing...
ID:	2174718   Click image for larger version
ID:	2174719   Click image for larger version
ID:	2174720   Click image for larger version
ID:	2174721   Click image for larger version
ID:	2174722   Click image for larger version
ID:	2174723   Click image for larger version
ID:	2174724   Click image for larger version
ID:	2174726   Click image for larger version
ID:	2174727   Click image for larger version
ID:	2174728   Click image for larger version
ID:	2174729   Click image for larger version
ID:	2174730   Click image for larger version
ID:	2174731   Click image for larger version
ID:	2174732   Click image for larger version
ID:	2174734   Click image for larger version
ID:	2174735   Click image for larger version
ID:	2174736   Click image for larger version
ID:	2174737   Click image for larger version
ID:	2174738   Click image for larger version
ID:	2174739   Click image for larger version
ID:	2174740   Click image for larger version
ID:	2174742   Click image for larger version
ID:	2174743   Click image for larger version
ID:	2174744   Click image for larger version
Old 07-28-2016, 12:01 PM
  #248
FlyerInOKC
FlyerInOKC's Avatar
Ignore those dripping noises its just the sound of us in the peanut gallery drooling all over ourselves staring at your photos!
Old 07-30-2016, 09:42 AM
  #249
jwharkinz
jwharkinz's Avatar
ONE !
as in one wheel pant covered.
I covered the elevators and the wheel pant pieces, now they will be painted to match. Gonna finish the other wheel pant this weekend(yea, it takes that long). I learned that getting greedy and rushing the application does NOT pay off.
... some pics
ID:	2174965   Click image for larger version
ID:	2174966   Click image for larger version
ID:	2174967   Click image for larger version
ID:	2174968   Click image for larger version
ID:	2174969   Click image for larger version
ID:	2174970   Click image for larger version
ID:	2174971   Click image for larger version
ID:	2174973   Click image for larger version
ID:	2174974   Click image for larger version
ID:	2174975   Click image for larger version
ID:	2174976   Click image for larger version
ID:	2174977   Click image for larger version
ID:	2174978   Click image for larger version
ID:	2174979   Click image for larger version
ID:	2174981   Click image for larger version
ID:	2174982   Click image for larger version
ID:	2174983   Click image for larger version
ID:	2174984   Click image for larger version
ID:	2174985   Click image for larger version
ID:	2174986   Click image for larger version
ID:	2174987   Click image for larger version
ID:	2174989   Click image for larger version
ID:	2174990   Click image for larger version
ID:	2174991   Click image for larger version
ID:	2174992   Click image for larger version
Old 07-31-2016, 02:01 PM
  #250
jwharkinz
jwharkinz's Avatar
polish mode...
ID:	2175305   Click image for larger version
ID:	2175306   Click image for larger version
ID:	2175307   Click image for larger version
