So Im Building A LST2 Racer....THE DAY AFTER THE TRACK
#76
RE: So Im Building A LST2 Racer.....Check It Out!!!
ORIGINAL: blackrain
truck is coming along beautiful good job so far. i have u full hoped up revo also that i barely touch
thanks man IM DIEING TO TAKE THIS THING up to mills pond to race it.......i ended up selling that CEN nemisis and with the money and bought this instead..........thanks for the info on how to mod the motor mount to fit a normal big block........im sure the info will come in handy one day!!!!
how many LST"S are at mills pond???
#77
i would say about 5 mostly revos and buggys and a few truggys. three of the 5 lst would be me my brother and my friend
#78
hey guys quick question!!!!
at ur local races in the MT class what r the usual top 3 on the podium??? just wondering...
also today i bought a transponder for the incredibably price of 20 dollars where do u guys like to mount it on ur LST's?????
#79
TX
At my track the three best drivers are always in the top 3 spots.
I mount my transponder over the hole where the reverse servo used to go.
#80
ORIGINAL: 2DMaxLST!!
#81
TX
I run disks that are made for the 8ight T. Do not attempt to use these type of brake setups for bashing or with servo's that have less than say 180oz/in of torque. That being said they have the most linear and easily modulated braking action I've ever felt.
This worked great but then glazed over, I went back to stock 8ight T brakes. I think this one would be fine if I went back up to +30 on my exponential along with some other linkage changes I have made recently.
#82
#83
well guys here is the FINAL LOOK of my LST2 i painted a new body i rembered i had in the closet tell me what u think?!?!?
#87
PA
[IMG][/IMG]
[IMG][/IMG]
#89
Well guys here is some pics of the aftermath of being at the track doesnt it just make u wanna lick it????
im kinda bummed tho i stripped a wheel hex and it was completely my fault.........im have to order a set of rims and wheels...........ima use the same exact set up tho......what sucks is i only had one set of wheels.........so now i cant use either truck............AARRRRRRGGGGG
#90
actually looking back on this.........im surprised losi being the great compeny it is has not made a easy off/on radio tray like the savage has...........it would actually be kinda easy desine of the LST2 can u image??? all the servos and radio gear somes off with about 4 or 5 screws........and then just HOSE IT DOWN!!!! LOL
#93
Well guys i knew i wasnt gonig to be able to find the tire here in miami at the moment i knew i was gonig to have to 50 about 50 miles just for a tire SO
i did the whole unglue the tire from the rim thing and belive it or not it actually worked i boiled the rim in water for and hour and when i took it out the rim basicaly melted off the rubber so i saved a tire!!! the rim was what was cracked i knew i could find a rim before tonight but i douted i could find the same one's as the others...........guess what......I FOUND IT!!!! at a lhs about 5 miles away i already mounted and glued the new rimits bein drying for about 2 hours and i wont be at the track till about 2 hours so 4 hour dry time is ok i guess hopefully it doesnt crap out
tonight is race night!!!! so im one happy camper plus since i have my own personal trasponder now this is gonig to be very exiting!!!
#94
MiamizFinest, glad to see you're happy with your new LST2. Hey, here's a little improvement over the Ronald McDonald. Nice and simple.
#95
ORIGINAL: TeamLosiFan
oh hell yea thats a awsome paint job man!!!! looks real good!!!!
tonight the track got rained out i didnt even get to unload my stuff and it started pouring............tomorrow ima try gonig to a diffrent track and raceing there practice tomorrow starts at 3 and race starts at 5:30............wish me luck!!!
#96
quick update guys i ordered a bunch of stuff for my truck and ill post pics of when i install everything
i ordered
losi 8ight disk brake
muggy shock bodies
muggy shock towers
muggy shock shafts
silver spring for the rear
aluminum ball bearing steeringcrankbell (i think thats what its called)
and my favorite upgrade i ordered!!!!!
thw whole CF convertion kit to take some big fat off the truck.......
im actually haveing durabitly issues with my truck i stripped the rims once and i actually stripped the mugen 17MM ALUMINUM HUB how the hell i did that i have no idea..............i have the 23MM hubs for the LST2 in my house (from when i had them on the muggy) ima install them and some offset wheels.........also the bearing had huge drag on them i litterally took every single part of this truck apart and cleaned everything.......its in peices in a box......ill take pics tomorrow
i ordered
muggy shock bodies
muggy shock towers
muggy shock shafts
#98
Remember the lower Muggy shock mounts!!
yea i ordered that too!!!!! i was actually looknig at my muggy when i placed the order to make sure i got everything........
but now that u posted that pic i just relized i 4got to order the RPM arms.......oh well ill order them next time i have spare stockers
#99
so MiamizFinest ball park how much did u spend converting your muggy? and how much would it of cost if u did not put all those race features on, just pretty much stock?
swing by the hpi area look for pythonfan wins[8D]
