just bought a lst
PA
just bought a lst
Hello Everyone,
I bought a used lst that is in prety nice shape.
it has all alluminum arms and knuckles on it but the problem i see is there is too much play in the arms and the knuckes not where the pins go through.
the pins holes are tight the arm just slides back and forth like the parts were not made right or someone was mixing and matching lst 2 parts they do not appear to be worn. alot of trucks have plastic shims to shim the control arms
this has nothing.
i do know see any name on the arms or knuckles
does anyone make tiny thin shims to take up the play.
i am not sure who made the arms and knuckles but there is way to much play
it is a lst it still has 14mm hexes and the old style axles.
let me know if anyone has heard of this
this has nothing.
PA
RE: just bought a lst
alot of people are telling me to go back to stock they say the are better because the will take the punishment
so i think i will and sell all the aluminum since i allready have the stock stuff coming from ebay
i think RPM sell a kit of shims for there arms for the lst. it would maybe fit your arms. but as you say your better getting the stock stuff, its more then enough and they are cheap if you break them.
i would like to have some RPM arms but i cant justify the cost when i can get 4 arms for 5-8$ on ebay.
and you may be interested in changing your pipe, look for the losi HT pipe that comes stock on LTS2/XXL
the one you have kills most of the power ...
Impala
Impala
MA
ORIGINAL: impalapolicepack
Impala
Impala
The thing about making your truck all aluminum is when everything is the same strength you have no clue where its going to break with the stock plastic you know where the vonurable parts are and chances are they are going to break in one of those week spots and not bend every piece of aluminum along the way.
