Go Back  RCU Forums > RC Airplanes > Electrics to Glow Conversions
Reload this Page >
Great Planes Super Stearman EP ARF 36"
Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
Old 09-17-2011, 09:54 PM
mike early
mike early's Avatar
Default Great Planes Super Stearman EP ARF 36"
Here is the new firewall. I left the magnets clear to see if they will provide enough forced to keep the cowl on.
Old 09-17-2011, 10:14 PM
mike early
mike early's Avatar
Default RE: Great Planes Super Stearman EP ARF 36
I'll put the fuel tank in here somewhere under the hatch.
Old 09-18-2011, 05:24 AM
c550
My Feedback: (16)
What engine are you planning to go with?
Old 09-18-2011, 07:36 AM
mike early
mike early's Avatar
I will try a Saito .40. Only because it is what I have. I'd prefer a Saito .30. This plane is almost weightless.
Old 09-20-2011, 07:12 AM
airraptor
My Feedback: (66)
I looked at this plane again yesterday and its small. the OS 20,26 and 30 would be great for it. the saito 40 will make it go pretty darn well. you will have a thrust of 2-1..............
Old 09-22-2011, 03:08 PM
mike early
mike early's Avatar
It IS small. Pretty strong we hope.
The thrust angle was in the motor box that I removed so I added some carpenter shimming at a 45º angle. It has about 2º of thrust angle in it so I am adding only about 1 degree of right and 1 degree of down. Probably not enough but I don't want to go any thicker to avoid pushing the prop too far forward and minimize the tail weight that I might need. Still undecided though. I could put a washer or 2 on the engine mount bolts to add more....
http://i49.photobucket.com/albums/f2...g?t=1316732847
Old 09-22-2011, 06:15 PM
mike early
mike early's Avatar
Engine sticks out more than I like. down thrust and right thrust are enough I think.
Old 09-26-2011, 04:48 PM
mike early
mike early's Avatar
throttle servo underneath. had to drill a couple holes in the firewall before I got it right.
Old 09-27-2011, 07:38 AM
airraptor
My Feedback: (66)
What is the weight and wing area?
Old 09-27-2011, 08:42 AM
mike early
mike early's Avatar
Wing Area: 365 in² (23.5 dm²)
Weight: 2.25-2.75lb (1020-1250g)
Have not balanced or weighed my particular plane yet.....
Old 09-27-2011, 05:19 PM
mike early
mike early's Avatar
The 4 ounce fuel tank fits perfectly and is centered over the CoG. A first for any of my planes.
Old 09-28-2011, 09:27 AM
airraptor
My Feedback: (66)
That engine will hover a 3.5lb plane at around 2/3 -3/4 power. this plane will be way over powered on 20% nitro. remember keep the pitch below 6 to keep the speed down. I would run a 11x6 on 20% or a 10x6 on 10% or less.
Old 09-28-2011, 03:47 PM
mike early
mike early's Avatar
Plane weighs 2.8 lbs. Zinger 11x6w too much prop for 15%. Overheated and deadsticked. Tried MA nylon 10x7 scimitar and flew better but over revved. 10x8 MA nylon scimitar ran the best so far. Will try 11x6 TF powerpoint next time. Want a wood prop on this plane. Got 3 flights in. Photo is after a 9 minute flight. 4oz tank. Insane efficiency with the Saito .40.
Elevator cross wire got a bit loose after the day's fun. Will open the covering and throw some CA in there and see.
Old 09-28-2011, 04:18 PM
mike early
mike early's Avatar
Nice evening at the field.
Old 09-28-2011, 04:20 PM
mike early
mike early's Avatar
It only lets me add one photo per post.....
Old 09-28-2011, 06:52 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Looks pretty sharp with the Saito hanging out a smidge! I like the prop hub you added.
Old 09-29-2011, 09:02 AM
airraptor
My Feedback: (66)
Look to get a ZOAR/Falcon prop maybe even a MA wood prop but the zinger wood props are about the worst out there.
Yes a 11x6wide is a very big load.
A Bolly 10.5x6 is also a great prop if you can find them.
I have an OS 30 that would be great on this one.
Old 09-29-2011, 09:43 AM
mike early
mike early's Avatar
Not many planes for a Saito .30. I encourage you to get one of these pretty little planes, sir.
Cannot find any of the suggested props...only large ones in those brands.
I think the TF Powerpoint 11x6 will be OK. We'll see.
Old 09-29-2011, 09:44 AM
mike early
mike early's Avatar
Thanks Kmot!
airraptor, not many planes out there for a Saito .30... I encourage you to get one of these pretty little planes, sir.
The magnetic cowling works great. Not an issue at all.
The hatch seems very tight as well. I was doing some aggressive spins and rolls and no issues there, either.
Old 09-29-2011, 12:16 PM
airraptor
My Feedback: (66)
http://www3.towerhobbies.com/cgi-bin...?&I=LXZ915&P=0 MA 11x6
http://www3.towerhobbies.com/cgi-bin...?&I=LXAPLR&P=0 XOAR 11x6 best wood prop out there thats cheap.
I have two of the Saito 40A engines and one OS 30 FS both stock and modded. it can turn a 8x6 at 16-17,000
Old 09-29-2011, 05:38 PM
mike early
mike early's Avatar
Haha, thanks. I'll buy them.
Old 09-30-2011, 03:52 PM
mike early
mike early's Avatar
Even though it takes a bit of elevator for inverted level flight, I will add some nose weight and see if it tracks a little better. I will use a brass prop hub. Weather is terrible for next few days.
Old 10-03-2011, 10:10 AM
tommy_b_o_y
looks real nice with that saito on the front. and your weight came out very respectable as well. nicely done.
Old 10-03-2011, 12:54 PM
mike early
mike early's Avatar
Thanks sir.
Maybe someone else will try this plane.
Horizon and Great Planes should release more small glow planes. But they do not. Probably will not.
Old 10-30-2011, 02:59 PM
Modelflyer
I bought one of the Stearmans a little bit ago and decided to put an OS 25FX in it. I have done this to an e-flite Pitts 15e and a Pulse 25e. They really worked out great. Hope the Stearman goes as well as the others...........
