Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
sirio .27 rotostart mod!
Old 03-30-2004, 03:45 PM
FooFighter
FooFighter's Avatar
Default sirio .27 rotostart mod!
if anyones interested this is what i had to do to fit my rotostart to the sirio
you will need 1 set of rotostart gears (hpi set for the 12/15 (bigger 1-way bearing) and a dremel thats it!
this is quite difficult to explain as i dont have a picture of what the rotostart did look like before i took a dremel to it so just imagine...
on the backplate theres a ridge which the ring of the back of the rotostart sits in and a deeper hole where the one way bearing spins round in..
all you need to do is just dremel that ridge out/down to allow the new rotostrt gear to fit in(drop in) you also need to just slightly dremel out the bottom of the casing to allow for the slightly bigger one way bearing..
ive tried to show in my picture below
the white circle is a kind of represents how its looked before hand and also the bit you need to dremel down to allow the new gear to fit nicely.
the yellow hex shape is where the 1-way fits in
and the grey shaded bit is the back of the rotostart that needs a minor dremeling down to accomodate the ever so slightly bigger 1-way bearing.
does this make sense?
if everything is nicely dremeled down the rotostart fits.turns and works like a dream!
hope this helps
Andy..
Old 03-31-2004, 08:43 AM
Ducklake
Default RE: sirio .27 rotostart mod!
Awesome!!
Can you buy the gears from Tower Hobbies, do you know?
Do you have the part #'s?
I'm definately going to try this
Thanks for the info.
Old 03-31-2004, 04:15 PM
vizaracer
vizaracer's Avatar
ive been trying to figure out how ot do this for the past week for my sirio. since sunday, when my pullstart broke 2 times. so i am sick and tired of it so i am putting the roto off my S-25 on it
Old 04-02-2004, 07:58 PM
Ducklake
top
Old 04-04-2004, 10:47 AM
Ducklake
I don't see how this is going to work.
The one way bearings are very different.
I'd like part #'s if somebody has them
Old 04-04-2004, 12:29 PM
vizaracer
vizaracer's Avatar
mine worked. i will test it in a day or 2. but it does fit now.
Old 04-12-2004, 02:17 PM
gbone
I have heard from someone else on this forum that Trinity does not recommend this mod as it can damage the crank.
Other than the fact that you have to remove the backplate when the piston is top dead centre I don't see what could be the harm in this. My pull start on my Racer Xl hasn't broke yet but I'd love to install the roto from my 25.
Anyone see how this alleged damage is possible?
G
