Phil Krafts Original Ugly Stick
Tower Hobbies
Logged in as Guest
  Printable Version
Stearman Biplane - RTF
Seller:  WarbirdII
Details:   $3,500.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Vintage & Antique RC >> Phil Krafts Original Ugly Stick
Page: [1] 2 3 4 5 6   next >   >>
Login
Phil Krafts Original Ugly Stick - 3/15/2005 10:54:26 PM
CCRC1
Status: offline
Phil Krafts original Ugly Stick was released to the public in the May-June issue of Radio Control and Model Aircraft World in 1966. For those of you who are stick fans this is the "real" original Das Ugly Stick scanned from the original magazine. This is before the airplane was released as a kit. The plans service was Grid Leaks plan service. Note- the original was designed with a cowl.
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Phil Krafts Original Ugly Stick - 3/16/2005 3:44:18 AM
kdheath
Status: offline
There is a story to the effect that the Stik was designed as a shop hack for the service department to test radios. Dunno if it's true, but a great story. I suppose Jensen was the first to kit the Stik? I've only had a few, and I think I've built six Stiks of various kinds.
(in reply to CCRC1)
       Post #: 2
RE: Phil Krafts Original Ugly Stick - 3/16/2005 4:45:57 AM
CCRC1
Status: offline
The story is definately true. The magazine construction article written by Phil Kraft that goes with the posted plan lays it out. The first paragraph of the article-
"The original concept of the Ugly Stik was to design a radio controlled aircraft which could be built in an absolute minimum of time. Its purpose was towards a flying test bed for new proportional control developments and an all around shop airplane which could be used as a loaner for visiting flyers, testing repaired equipment, and any use which required an airplane which could be considered as expendable."
I wonder if Phil ever thought that the airplane that took him 3 evenings to design and completely finish, would be one of the most built and flown designs in the history of R/C Aeromodeling.
(in reply to kdheath)
       Post #: 3
RE: Phil Krafts Original Ugly Stick - 3/16/2005 12:48:19 PM
Mike Denest
Status: offline
And then there are the offshoots. The Stik has to be the most imitated R/C airplane in history as well.
_____________________________
Mike Denest
R/C as it used to be: http://www.vintagercsociety.org
(in reply to CCRC1)
       Post #: 4
RE: Phil Krafts Original Ugly Stick - 3/16/2005 1:04:21 PM
8178
Status: online
The Jenson kit was very well done. I found that you could buy a kit on Monday and working only in the evenings (late) you could have it flying on Saturday. That was using MonoKote, the early ones I built using silk and dope ones took a lot longer. No super glue back then either. There were a few of us silk and dope hold-outs long after most people were using only MonoKote in the early 70s. They came out with a wing reinforcement modification when they discovered that the MonoKote covered wings were folding in flight. They do fly great!
(in reply to CCRC1)
       Post #: 5
RE: Phil Krafts Original Ugly Stick - 3/16/2005 2:36:05 PM
Mike Denest
Status: offline
On my Ugly Stik, I used silkspan and dope on the sheet parts and tried Ceconite 102 (had some leftovers) on the wing. I use it to check out radios and have a ball flying it. With a Veco .61 on the nose, I have plenty of power to do anything possible with the airplane.
Mike Denest
(in reply to 8178)
       Post #: 6
RE: Phil Krafts Original Ugly Stick - 3/16/2005 9:11:34 PM
CCRC1
Status: offline
Good news,
I have the above image of the original plans in a .pdf file. I took it to my local blueprint copier and he printed it out and was able to enlarge it using the scale drawn on the plan. He got it to within 1/32". Close enough for a Stik!
If anybody would like the .pdf file let me know and I can e-mail it to you.
Grid Leaks Plan Service is long out of business so I don't know any other way to get an original copy.
(in reply to Mike Denest)
       Post #: 7
RE: Phil Krafts Original Ugly Stick - 3/16/2005 10:23:17 PM
hankpajari
Status: offline
I just built a Jensen stick recently. It had been in the attic for more than 20 years. Used silk and dope on the wing because they tend to explode if you use monokote. Never trusted the modification you mentioned.
Have a Supertiger 60 Bluehead ABC ring on it.
Still haven't flown it, no time, but looks great hanging from the ceiling in the shop
Hank
AMA 62359
(in reply to 8178)
       Post #: 8
RE: Phil Krafts Original Ugly Stick - 3/20/2005 5:23:59 AM
911RC Guy
Status: offline
I'd like a copy of that pdf file of the stick. I've been out of the hobby for about 23 yrs and the stick would probably be a good plane to start out with again. How do I give you my email without posting it for all the world to see???
911RC Guy
(in reply to CCRC1)
       Post #: 9
RE: Phil Krafts Original Ugly Stick - 3/20/2005 6:27:49 AM
w8ye
Status: online
You can get the original plans from R/C Modeler Mag.. plan service.
I have a 2 sheet set in front of me. It shows a K&B 61 mounted on the nose.
The plans come with a copy of the construction article too.
http://www.rcmmagazine.com/e/env/0001Kr4lYuRlyVkoFo6I9W3/store/store-plans-alpha.html?link=/store/store-plans-catalog-tem.html&item=plans:PL-939
Enjoy,
Jim
< Message edited by w8ye -- 3/20/2005 6:37:39 AM >
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to 911RC Guy)
       Post #: 10
RE: Phil Krafts Original Ugly Stick - 3/20/2005 3:23:16 PM
HighPlains
Status: offline
Are the plans from RCM the same as the Grid Leaks plans? The GL's plans were published in 5/66 and are now available through the AMA's Pond plans for $10. AMA # 23959
Listed as "Das Ugly Stick"
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to w8ye)
       Post #: 11
RE: Phil Krafts Original Ugly Stick - 3/20/2005 3:52:16 PM
CCRC1
Status: offline
No, the plans from RCM are not the original plans. They are similar in construction/dimension but, are updated in the wing spar area to allow the builder to use iron on coverings. The original was covered in silk and dope and that added to the integrity of the airframe. Other areas are changed as well, such as the original was designed with a cowl and was drawn with a Veco .45.
I posted this thread for those of you who are vintage buffs and wanted to see the actual real original Das Ugly Stik. The one that RCM has came later and was in fact updated by Phil Kraft, but it was not the first one. A lot of folks refer to the Jenson kit as the original, but in fact it was not. It was the first commercially available kit of the airplane and it was changed/updated from the original Grid Leaks Plans.
< Message edited by CCRC1 -- 3/20/2005 5:14:07 PM >
(in reply to HighPlains)
       Post #: 12
RE: Phil Krafts Original Ugly Stick - 3/20/2005 4:11:47 PM
CCRC1
Status: offline
911RC, I just noticed that I do not have a "PM" Icon on my posts to allow you to send me a message, even though I have enabled it in my settings.
Click on CCRC1 on one of my posts and that will take you to my profile and there is a "PM" icon there. Use that to send me a message with your E-mail and I will send you the file.
Moderator- how do I get the PM icon to display on my posts?
< Message edited by CCRC1 -- 3/20/2005 4:15:41 PM >
(in reply to CCRC1)
       Post #: 13
RE: Phil Krafts Original Ugly Stick - 3/20/2005 10:39:58 PM
old-pilot
Status: offline
Here is the original magazine cover before RCM...I didn't build one until 30 years later..
Click for fullsize
Roy C., AMA5272, w0shy,
member of 49th Jumbo Squadron
(in reply to CCRC1)
       Post #: 14
