Nitro Engine Care And Breaking In/Starting Instructions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Nitro Engine Care And Breaking In/Starting Instructions
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Nitro Engine Care And Breaking In/Starting Instructions - 3/21/2005 12:00:46 AM
Biohazard53188
Status: offline
Nitro Engine Care And Starting Instructions Ver.1<hr>
NEVER run your engine without an air filter!
Materials Needed:
Gas Powered Car
Glow Fuel (10% Nitro Fuel)
Fresh Glow Plug
Glow Warmer
Pull Start / Starter Box / EZ-Start / Roto Start / Drill Start
Glow Plug Wrench
Small Size Phillips Screwdriver
Something To Punch When Frustrated
Preparing Your Engine For Start Up:
Turn your engine over once by hand using the flywheel. You will come to a point where the engine is difficult to turn over. This is called the TOP DEAD CENTER (The point where the engine is compressing the air and fuel mix with the most pressure it can produce). A good idea for a first start up of and engine is to use a hair dryer to heat it up for 2 minutes and this will help make it easier to turn over and start. Mark an arrow with permanent marker where your Top Dead Center is on your flywheel. This will help you in determining your Bottom Dead Center. First make sure that your glow plug starter is fully charged and ready to be used, next take off your air filter. Turn on your radio and adjust the throttle trim/carb accordingly. The air intake should stay open at least 1mm when the car is at idle.
Starting Your Engine:
Pinch the pipe line(the fuel line going from your tank to you exhaust pipe). While plugging the exhaust turn the engine while watching the fuel line for any movement. You will see fuel move through the line and up to the carb. Once it reaches the carb turn the engine over once more. Now pull on the starter (if you are using a pull start, If not then use the starter as directed in the instruction manual) exposing only 75% of the string so you do not break the starter. NOTE: These movements need to be short and quick.
Once the engine starts stop pulling on the pull start and allow the plug warmer to camp on the glow plug for an extra 5 seconds. Give it some small amounts of throttle in order to keep the car alive (don’t panic if the car dies, just start it up again).
Breaking In The Engine:
Once it stays running you need to allow the car to “Free Idle” for one whole tank of gas. This means that you need to get rid of all forces working against the engine by placing the center of the car on an object that is above the ground allowing the wheels to spin freely (Hence the name “Free Idle”). Run it a little over idle and don’t allow the engine to heat up much. Try keeping it under 1/4 throttle. Run it like this for 2 more tanks of gas, allowing a ten-minute break in between the tanks. You will no need to position the piston at Bottom Dead Center after letting the engine cool all the way. Put a line on the opposite side of the mark on the flywheel. Go ahead and start it up again and now you should find that the engine starts up a lot easier. You can now start tuning the engine for optimum power and performance.
Tuning The Nitro Engine:
Start off by driving around at full throttle on some flat ground. Make sure you pay attention to the noise the engine is making and the smoke the exhaust pipe is producing If the engine sounds like it is making a screaming sound and the exhaust is only producing little or no smoke then the carb is set too lean and you need to turn the needle 1/8 turn toward open. If the engine is making a boggy sound and there is a thick trail of smoke then the carb is too rich and you need to turn the needle 1/8 of the way opposite of before.
       Post #: 1
RE: Nitro Engine Care And Breaking In/Starting Instruct... - 3/21/2005 7:13:04 PM
enjoymentboy
Status: offline
WOW!!! You've got some info in there that will really shorten an engine's life and performance quite a bit if not kill it outright.
NEVER break in an engine by free-idling. DON'T keep it at a very low temp and running rich. That's the old-school way and it has been shown to no longer be the best way to break in an engine. You want to get the engine up to operating temp (200°F - 240°F) as soon as possible and keep it there for 3 minutes running at no more than 1/4 throttle. Now shut down the engine, put the piston to BDC and let it cool completely. Do this over and over until you have around 25 minutes of runtime on the engine and then repeat it all over again but going up to 1/2 throttle. After the next 25 minutes is passed your engine should be nicely broken in.
This is known as the heat-cycling method and with the materials that are in use nowadays is the best way to break in your new engine. It can take a while to do right but it is well worth it.
I don't get this part. If you pinch off the pressure line why would you also plug the stinger? There is no need to touch the pressure line when priming. Plug the stinger and turn over the engine until the fuel just reaches the carb. Turn it over 2 more times and you are all set.
NEVER tell a newbie to start off at full throttle. You never want to do anything other than brief bursts of WOT. 3-5 seconds at the most...unless you like broken conrods and shot bearings. Sure you can do high speed passes, but not full on WOT for extended periods of time.
I can appreciate the fact that you are trying to help as many people as you can, but please make sure that you are not passing on info that is either out of date or simply harmful to THEIR equipment. I've been into RC for 20+ years now and the changes that have come about are amazing. Everyone must update their information from time to time keep up to date.
Enjoymentboy
_____________________________
If at first you don't succeed...you need a bigger hammer!
(in reply to Biohazard53188)
       Post #: 2
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/23/2005 8:00:34 PM
Cummins
Status: offline
Wow, thats two completely opposite opinions. I'm a relative newb and this is how I broke in my engine and have had no problems with it:
I place the car on a stand and started it up. I let it idle for a tank, I then repeated this. After the second tank of idle. I placed it on the ground and did very slow (1/3 throttle max, not even that much) passes along a straight road, while adjusting steering trim. I repeated this a lot, gaining in confidence (and speed) over about 6 tanks. NOTE: This was my first real RC car so I was learning how to drive at the same time, I never went to full throttle at all through the whole break in perios, and still havn't really gone above 35mph. After my 6th tank, I took it to a big open car park and let all hell loose...
A while ago my account was hacked.
If you know anything about this,
(in reply to enjoymentboy)
       Post #: 3
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/25/2005 4:23:40 PM
Philster
Status: offline
I agree with the objections to the thread starters instructions.
That stuff is old school.
Follow the damn manufacturs instructions. Good practice is heat cycling, and cooling with piston at BDC. Common is running rich, and running blips at full throttle.
You can't just give instructions to the whole RC community like the thread starter did.
Main Rides: Picco P3-.28 Powered Kyosho Inferno GT and Sportwerks Mayhem ST .26
(in reply to Cummins)
       Post #: 4
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/25/2005 6:22:28 PM
Cummins
Status: offline
quote:
ORIGINAL: Philster
Yeah, different engines require different breakins. I use this as a rule though: if the manufacturer says use 4 tanks to break in, I use 8. If the manufacturer says use 9 tanks, I use 13. Basically the 4 tanks after the manufacturers recommended break in, I would still run it easy and slow.
(in reply to Philster)
       Post #: 5
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/27/2005 2:16:59 AM
Fuelman
Status: online
OK Folks, keep in mind the purpose of this thread- to help people break in an engine correctly.
Now, I will go over it quote by quote on what is and is not the correct method of breaking in an RC Car nitro engine.
1. Before starting a brand new engine, take out the glow plug, take off the carb, and take off the backplate (this will not void your warranty) and with great care not to splash it around, rince the engine insides with glow fuel or kerosene or another suitable solvent. Flush the carb and the cylinder as well, rotate the engine over by hand a time or two. This gets a lot of the metalic dust out of the engine that has been left over from the manufacturing. You will be surprised on how much metalic dust comes out of some engines. Is it necessary? I think so for longevity reasons. Dry it off and lube it up with some castor oil or after run oil or even a little good ole motor oil. Reassemble engine and install it in the car.
2.
This is not necessary nor does not hurt anything. Remember that top dead center is when you turn the flywheel against great resistance (the pinch) and then it all of a sudden has slack in it.
Adjust all your linkages and radio/ throttle barrel, do your plumbing etc.
Always check and set the high speed and low speed needles according to the instructions, they are sometimes not set correctly at the factory.
Put fuel in tank, get it primed, etc
3. Preheat the top of the cylinder to relieve some of the pinch. A hair dryer might do it but it does need to get a lot hotter than a hairdryer will get, but anything will help here. Make sure you throughly heat it up.
Put on your glow driver and fire it up
4.
quote:
.... allow the plug warmer to camp on the glow plug for an extra 5 seconds. Give it some small amounts of throttle in order to keep the car alive (don’t panic if the car dies, just start it up again).
You need to leave the glow driver on there and keep it running with the throttle, do not be afraid to spike it a bit to keep it running and getting it warmed up. Hold a nice real high idle and take off the glow driver. If it stalls when removed, its either too rich or the plug is bad. Start it back up.
5.
Absoutly wrong unless you want to be buying pistons and sleeves long before you realy need to.
Do this:
Once it will start and run without the glow driver on, let the wheels freewheel and hit the throttle. If the engine is stumbling and not cleaning out to run at high speed throttle, lean out the high speed needle just enough to allow it to run in a nice clean mode. As soon as it will run clean, put it on the ground, and run it around. Do not just putt around at a low throttle, drive it!!!, take it to full throttle for very short periods and varying throttle positions. you may have to pit real quick to adjust the needle so its not so rich that it will not clean out during transition. Run it for two to three minutes and then bring it in and shut it down to cool completly to ambient tempreture.
6. Start it up once cooled off and do it again. Repeat the procedure (heat cycling) a minimum of three times but I really prefer the first 15 minutes of the engines life is nothing but heat cycling. After the first run, you will probably need to start tweeking the low speed needle a bit and the high speed a bit as well, start driving it harder and harder each run. You can accelerate the cooling by holding the hair dryer over it set to just blow air but DO NOT SHOCK COOL IT WITH FUEL OR ALCOHOL during the break in heat cycling time.
7.
Forget about the smoke and use your ears. I say this because the oil quality and type in the fuel is different for every manufacturer and some fuels smoke very very little making it hard to use that as a tuning tool. Yor ears are the most important tool you have.
If it is burburly from an idle, lean it out about an eighth of a turn at a time untill it spools up crisp and clean off an idle. Of course you can not do this on a cold engine, only tune on a fully warmed up engine. You will not need a temp gun either.
8. When you're done running for the day, pinch the fuel line and let the engine die from starvation, never flood it out by putting your finger over the exhaust. If you have wet fuel in the crankcase, it will absorbe moisture and potentially rust up bearings and the crankshaft. Run it dry and that way little if any liquid fuel is left in the engine to pull moisture in. Use an after run if you like.
quote:
....keep it there for 3 minutes running at no more than 1/4 throttle. Now shut down the engine, put the piston to BDC and let it cool completely. Do this over and over until you have around 25 minutes of runtime on the engine and then repeat it all over again but going up to 1/2 throttle. After the next 25 minutes is passed your engine should be nicely broken in.
This is not completly necessary. You can run it up to full throttle for short periods during the first couple heat cycling runs, it only helps. 25 minutes of heat cycling anything will not hurt it one bit, but no need exists to restrain yourself to 1/4 or 1/2 throttle in breaking it in. Getting the thing to operating temp is the critical thing (not too rich and not too lean).
quote:
.....NEVER tell a newbie to start off at full throttle. You never want to do anything other than brief bursts of WOT. 3-5 seconds at the most...unless you like broken conrods and shot bearings. Sure you can do high speed passes, but not full on WOT for extended periods of time.
Absoutly correct, although the bearings are unaffected by throttle and the con rods will only get tossed when the engine is running so rich athat the piston is being pinched in the sleeve top and stressing the rod too much. yet another reason not to run these things too rich.
quote:
.....Follow the damn manufacturs instructions. Good practice is heat cycling, and cooling with piston at BDC. Common is running rich, and running blips at full throttle.
Yes, heat cycling is good. Most people get in trouble by reading the instructions because most of the instructions I have read are completly incorrect on how to break in the engines. Recently I read the Fantom instructions and they are right on target. Use the instructions for what the needle settings should be and other generic issues.
quote:
.....Yeah, different engines require different breakins. I use this as a rule though: if the manufacturer says use 4 tanks to break in, I use 8. If the manufacturer says use 9 tanks, I use 13. Basically the 4 tanks after the manufacturers recommended break in, I would still run it easy and slow.
Yes, different engines do require different break in procedures. For iexample- Ringed engines are broken in completly differently than I describe, and so are lapped iron piston and sleeve engines, ABC/ABN/AAC engines are broken in like I describe.
Last I knew, all rc car and truck engines were of the ABC type and therefore can be broken in the way I describe. Brand name of engine does not matter, car, truck, airplane, boat, if its an ABC type, it can be broken in the same.
Here's my disclaimer- I do this for a living, run engines and try to destroy them, every way imaginable. I also try to see how long an engine will last when everything is done right. I've been doing this for a long time with airplanes, cars, helicopters and boats.
I do not sell parts, I do not make engines, I do not own a hobby shop. I do not have any insurable intrest in making a profit from selling parts, therefore I have no reason to have you break in an engine in a manner harmfull to the longevity of the engine. I make fuel guys, and have every reason for you to have a good running engine that lasts a long time so you use and buy lots of fuel. I make no money when my customers are waiting for engine parts or waiting for somebody to fix it.
Hope this helps.
Fuelman
< Message edited by Fuelman -- 3/27/2005 2:30:38 AM >
Fuelman
Cooper Fuels LLC
       Post #: 6
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/27/2005 12:12:31 PM
Cummins
Status: offline
damn, thats possibly the most controversial method of breaking in I've ever encountered. What company do you work for?
(in reply to Fuelman)
       Post #: 7
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/27/2005 6:42:32 PM
Fuelman
Status: online
What is so controversial?
I am the owner of a specialty glow fuel and specialty oil company, Cooper Fuels LLC
Fuelman
Cooper Fuels LLC
       Post #: 8
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/27/2005 7:52:28 PM
Cummins
Status: offline
Well, your telling people to throttle it when breaking it in for starters... want a list?
       Post #: 9
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/28/2005 3:14:38 AM
Fuelman
Status: online
Cummins,
I know that this goes across the grain from what the car and buggy industry has imprinted in everybodys minds, but feel rest assured that the ABC engines used by the airplane and boat crowd have been broken in this way for the last 30 years. I know lots of guys running ABC type two strokes in planes with over 50 gallons through the engine.
What I'm saying above is run it, don't hammer the snot out of it, but don't let it sit and putt around either or do any prolonged ideling. For these ABC type engines to break in properly, they need a load put on them.
If you let these things sit and idle, super rich, with the wheels off the ground for break in, you just rapidly accelerated the wear on the piston and wore away a great deal of the pinch that makes the ABC type engine run. If you do it (break-in) the way an ABC type engine is supposed to be done (my way), and never run it too lean or too rich, you will have an engine that will far outlast (in gallons) one that is done the way the thread origonator suggests.
Do what I've done, take two identical engines in two identical cars (in this case Losi XXXNT's w/ stock Mach 15 engiens), and use the same fuel and glow plugs. Break them in on the same day, one is done in a similar fashon as the thread starter (car #1), the other one the ABC way (car #2).
Car #1 had the pinch nearly gone by the time the third tank was through. The engine ran good for about two gallons then it started to lose performance rapidly and became very erratic. Car #2 Was performing extremely well and was a two pull starter, with no hot start problems, it out performed car #1 every time and is still going strong with over 20 gallons through it. Car #1 was rebuilt using factory piston, rod and sleeve and then broken in the ABC way, it has about 15 gallons through it now ans still going strong. Keep in mind that my three boys are really hard on these cars and when they are playing with them, they will burn three or four quarts any time they get them out.
So, what is the rest of the list?
Fuelman
Cooper Fuels LLC
       Post #: 10
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/28/2005 4:54:39 AM
uwadockers
Status: offline
Yo Fuelman... I've heard about your method of breaking in but i don't have the courage to do it.. Anyways, deciding between 421B and P5.. Any suggestion which one is a better mill for somewhat technical track with a 40 metres straight?? And after the first start, you mentioned 'drive'.. Do i full throttle the fellow or just blip??
       Post #: 11
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/28/2005 8:52:14 AM
jsn
Status: offline
My car engines lasted a few gallons UNTIL I said screw it and broke them in just like I did all my plane and boat engines just as fuelman lay's out in his post... at the same time I QUIT TRYING TO TUNE TO TEMP! this is such BS! I Flew and and tuned for year's with out temp readings and enjoyed engines that have more gallons of fuel through them than I care to count... all the sudden I have to run between 220-240 if I want my engine to last? BS! and don't tell me plane engines run cooler than car engines either... THEY DON'T! car fuel has more oil in it... NOT! there are so many myth's and old wifes tail's in the car engine industry it's sad... Heat cycle your engine for breakin, tune your engine so it's not lean or RICH, let the temps be what they will and run the darn thing
John
< Message edited by jsn -- 3/28/2005 8:56:47 AM >
(in reply to uwadockers)
       Post #: 12
RE: Nitro Engine Care And Breaking In/Starting Instruc... - 3/28/2005 12:14:29 PM
Fuelman
Status: online
