RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $119.00   |  10/11/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/27/2006 3:47 PM
deljon
Score: 100
Last Login: 11/5/2009
Status: offline
After I drilled all the holes, I took it back apart to do a little more sanding to smooth out the "turning" marks in the alum. I first used an orbital sander with 150 grit paper, then went over it again with 250 grit. After that I wet sanded it by hand with the 250 grit. It came out pretty smooth, but I think I'll go back over it with 320 grit wet sanding. Probably don't need to but will anyway.
Once I sand it again I'll reassemble using the brass brads, bending them over and lightly tapping them down. You can then clip off some of the excess if you like, then use some epoxie and go over the back side to secure all the "rivets".
_____________________________
FOKKERS FOREVER
Hide Signatures
(in reply to deljon)
       Post #: 76
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/27/2006 10:11 PM
bookmaker
Score: 100
Last Login: 11/1/2009
Status: offline
I had not thought of using those little bar clamps to hold things together while drilling. I have several and will definitely use them when I get to that stage.
Dale
Hide Signatures
       Post #: 77
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/30/2006 4:23 PM
abufletcher
Score: 1517
Last Login: 11/8/2009
Status: online
Can someone post the website for Glenn Torrence Models. I always have a heck of a hard time finding it through Google.
Hide Signatures
       Post #: 78
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 7/30/2006 4:58 PM
V2PLUS10
Score: 100
Status: offline
www.flygtm.com
Randy
Hide Signatures
(in reply to abufletcher)
       Post #: 79
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/2/2006 10:53 PM
deljon
Score: 100
Status: offline
Dale.....I use those clamps alot. I have three differant sizes
Ok, back to the cowl, I now have all the "rivets" in, bent and epoxied.
Here it is from the front, I gave the whole thing a good wet sanding with 600 grit paper and it's ready to prime.
FOKKERS FOREVER
Hide Signatures
(in reply to V2PLUS10)
       Post #: 80
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 9:37 PM
jtisch
Score: 100
Last Login: 11/7/2009
Status: offline
Del,
Looks great, as usual for you. It looks like the front plate of the cowl extends down a little further than the one that came in my 1/4 scale kit, which is an improvement. Looking at different DRIs that front cowl plate seems have have had different lengths as production went on. It is much easier to cut it down than to add more on.
Would you believe I did all the holes in my cowl with a pin vise? I was living in an apartment at the time and didn't have a drill press or electric drill then. I may not always be the brightest bulb on the X-mas tree!
Can't wait for the fuselage to start! Do you have the plans for it yet? One thing I did on my 1/4th size fuse was to replace all the cross members in the cockpit area with dowel, to better represent tubing. Perhaps you noticed from the photo over at the 'Drome.
Keep up the good work!
J
WWI Aviation T-shirts
Hide Signatures
       Post #: 81
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 9:55 PM
deljon
Score: 100
Status: offline
J.....MAN that is a lot of drill'n with a pin vise. It was worth it though wasn't it??
Yes, I noticed the dowels in the cockpit area. when I get the plans I'm going to do the whole fuse with dowels just as Glenn did with the DVI. It really makes the whole framework look authentic............
Del
FOKKERS FOREVER
Hide Signatures
(in reply to jtisch)
       Post #: 82
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 10:01 PM
bookmaker
Score: 100
Status: offline
When you get around to it, I have some very close up photos of the cowl hold down cable connections to the firewall. They were taken of the E.V replica in Alabama, but I'm sure they are the same for the DR I.
Dale
Hide Signatures
       Post #: 83
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 10:07 PM
deljon
Score: 100
Status: offline
I would love to see them Dale
Del
FOKKERS FOREVER
Hide Signatures
(in reply to bookmaker)
       Post #: 84
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/3/2006 10:10 PM
bookmaker
Score: 100
Status: offline
OK, I'll get my D VIII photos together.
BTW, I really like the DRI project.
Dale
Hide Signatures
       Post #: 85
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/10/2006 5:12 AM
jtisch
Score: 100
Status: offline
quote:
ORIGINAL: deljon
You bet, I'm doing the rib taping now , so the cowl drilling doesn't seem so bad now.
Hide Signatures
       Post #: 86
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/20/2006 3:07 PM
jo-go
Score: 100
Last Login: 6/4/2007
Status: offline
Hi Del,just discoverd your wonderful work-I have a 1/3 fokker DVI kit on order which I shall receive in October and I am very exited about the project since it is practically identical to the DRI{fuselage and rear end}I am currently scratch building the spandau guns and I am happy sofar with the result--the barrel cooling slots required absolut concentration on the milling processafter having plotted the individual slots on paper ,and it went ok, cocking levers,top hatches and safety catches are as per fullsize funktional,what woories me a bit wher to get the right gunmetal paint --found out the original ammo dimensions { 80,6mm total length]so next week I will tackel making the casings from 4.5 mmDia brass tubing and bullets using hardwood dowling--all great fun but took me sofar oodles of hours!- But at least I won't have to worry about them once the kit is built--Glenn does fantastic work also and it is a pleasure to watch your progress! --best wishes and keep it up!-regards jo-go
Hide Signatures
       Post #: 87
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 1:51 AM
WinterHawke
Score: 100
Status: offline
Just a couple of photos from this last weekend's trip to Muncie, IN - Del brought the Dr.1 bits along with his for Show-and-Tell:
First up, a hard-at-work von Delby surveys the scene:
And Del's handiwork so far:
That is one very big cowling, y'all!!
Can't wait to see what comes next, Del!
'til later,
Lee
Arguing with a Scale Judge is like wrestling a pig in the mud - After an hour or so you figure out the pig enjoys it!
Hide Signatures
(in reply to jo-go)
       Post #: 88
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 2:12 AM
Prop Nut
Score: 100
Last Login: 10/6/2009
Status: offline
Del.....why is it that you look grumpy in all the pictures that I (and Lee it would seem) took of you?
Click to see fullsize image.
Click for fullsize
< Message edited by Prop Nut -- 8/24/2006 2:05 PM >
Scope? Listerine? Or Prop Wash?
Hide Signatures
(in reply to WinterHawke)
       Post #: 89
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 2:39 PM
WinterHawke
Score: 100
Status: offline
quote:
ORIGINAL: Prop Nut
Dunno - probably 'cause he only got to fly eight times on Friday, and it got a bit too windy on Saturday afternoon!!! I have seen him happy at times:
He just doesn't like to be not flying - imagine that!!!
Dave, great picture of our von Delby - had a great time last weekend hanging out with everyone.
'til later,
Lee McD
Hide Signatures
(in reply to Prop Nut)
       Post #: 90
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 3:52 PM
Prop Nut
Score: 100
Status: offline
Lee, I had a great time as well. Next year I will bring four planes.....odds are that one of them will work this time!
David
Hide Signatures
       Post #: 91
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/24/2006 8:43 PM
deljon
Score: 100
Status: offline
Come on guys, give and ole man with a bad back a little break. Must have been the Meds. (That's my story and I'm stick'n to it)
Besides, if ya hadn't been so sneaky and took them when I was look'n, I might have smiled (well a little maybe)
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 92
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/25/2006 1:23 PM
abufletcher
Score: 1517
Status: online
That's just a look of "teutonic determination!"
Click for fullsize
Hide Signatures
       Post #: 93
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/25/2006 3:36 PM
deljon
Score: 100
Status: offline
I'll go with that.........Thanks Don
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 94
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 8/25/2006 5:46 PM
Prop Nut
Score: 100
Status: offline
Hmmm......yah know what Don? That does look alot like Del...............
Click for fullsize
< Message edited by Prop Nut -- 8/25/2006 5:54 PM >
Hide Signatures
       Post #: 95
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 9/7/2006 1:57 PM
jo-go
Score: 100
Status: offline
Hi DEl--your attention to detail is great,what ashame it all will be covered up in the end-seems everybody is off to Rheinbeck,wish I could make the trip too,but 24 hrs on an aeroplane is just not on anymore--hoping that there will be some nice shots from Rhineback comming--keep up your good work,and remember-- " he who never made a mistake never made anything"!!--
regards jo-go[
Hide Signatures
       Post #: 96
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/1/2006 5:07 PM
Bud Faulkner
Score: 105
Last Login: 7/28/2008
Status: offline
WOW! That's a georgeous DRI in the picture...is that a Torrence kit? What engine?
Bud
< Message edited by Bud Faulkner -- 11/1/2006 5:08 PM >
"The propeller is the fan that keeps the pilot cool, turn it off and watch him sweat"
Hide Signatures
       Post #: 97
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/1/2006 6:48 PM
abufletcher
Score: 1517
Status: online
So Del, when are we going to get another installment?
Hide Signatures
(in reply to Bud Faulkner)
       Post #: 98
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/1/2006 8:52 PM
deljon
Score: 100
Status: offline
Bud.....Thanks for the comment, the Dr.1 in the picture is a BUSA kit kicked up a notch. I copied Glenn's wing tip skids and also the tail skid. Did not bungie the main gear but wish I had. May do that over the winter. It weighs 15lb dry and is powered by an older OS 160 twin. Flies nice and scale like at about 1/2 throttle. It flies like a dream.
Don.....Waiting on Glenn to catch up, after Rhinebeck he had to put in some extra time with his day job, (I think some trips were involved.)
Last I talked to him he was trying to get finished up on the DVI and was going to get started on the top wing for the Dr.1. One of big things he was looking into was designing the wing attachments to make the field set up and takedown and also transportation as easy and simple as possable and still keep the scale integrity of the model.
I'm ready when he is.
Del
FOKKERS FOREVER
Hide Signatures
       Post #: 99
RE: Glenn Torrence (GTM) 1/3 Scale Dr.1 Build Along - 11/1/2006 11:04 PM
Prop Nut
Score: 100
Status: offline
Good to see that your still with us Del.
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.703RCU1
