Permax + KMI + Quark == happiness at 50mph :)
WA
It seems I've FINALLY found a motor that can get me to 50+mph on 3s lipo in my mini inferno without overheating the poor quark. And that motor is (you guessed it) the permax 400/4d with a 3.2mm shaft so I can run bigger pinions
I'm running the permax in a 3racing fan/heatsink engine mount wired directly to 11.1v (poor fan is rated at 7.2v). The fan keeps it at a pleasant 120F while the ESC tops out at just under 160F. I'm very happy with the fan so far - lowers motor temps about 30F (no joke!).
It's running an 18T pinion and a 30T 3racing delrin spur / slipper replacement gear with 1/10 touring car foams for a theoretical top speed (assuming droop to 10.5v, 5200kv, and 61mm tire diameter) of 49.25mph. In previous GPS testing, the permax tended to run a bit faster, so I'm probably hitting 50+.
From the temps, I can probably bump it up even more. I might try a 20T this weekend...we'll see. [8D]
I wrecked my brand new (body isn't even painted yet) brushless / lipo xxx-4 today so the poor KMI is going to have to hold me over until replacement parts show up. The neighbor had the nerve to put cinder blocks in his yard.... [] I came darn near thermaling the mamba max I just got today too...who'd have thought 26T and 65mph would be over-geared for a 7700kv motor!?
CA
RE: Permax + KMI + Quark == happiness at 50mph :)
I knew it would work,,, but no one would take the time to find the right gearing,,, im glad you did,,,, I will post this link in halfeight.com and also one18th.com if you dont mind,,, I even think mr. mugen had his doubts aout the motor....
glad to see this motor is well rounded for any vehicle,,,,, now it is time to race it among other KMI
WA
I figure if I mount a small fan to the ESC heatsink like I have on the motor mount I can push it even further. We'll see...
Go ahead and cross-post; everyone should enjoy permax happiness! [8D]
CA
i posted the links here. http://halfeight.com/forums/showthre...7167#post27167
and here.. http://www.one18th.com/forums/showth...279#post400279
CA
it wont work,,,, the pinion gear you would have to use wont fit the chassis,,,, it would need to be something as rediculous as 26/55 ,,,, but why would you subject yourself and limit yourself to something like that when the mamba motor is a perfect match,,, for the cars gearing and weight
CA
well put it this way.. my ammo 3900 motor in my detta st geared at 19/41 was about as fast as my rc18t with mamba 8000 motor geared at 12/60.. about the same torque and same speed.. this is with a 2s lipo..
WA
ORIGINAL: jaejw1
how fast do you think it woul be just with a 2s lipo.. and maybe a larrger pinion
The above calculations assume the cells are at 3.5v under load and tire diameter (1/10 foams) is about 2.4".
The motor is also available in a 2.3mm shaft version that can use the stock pinion. http://hobby-lobby.com/brushless-multiplex.htm
This combo on 3S Lipo is perfect for all around use.
Mike.
Mike.
Well, that what I am using, permax 2.3mm with quark. I have hard time to looks for pinion gears for it. Anyone know what 2.3mm shaft size gear that fit KMI? I am running GPM 16T/ Atomic 32T with 8-cell 1500 elite battery pack. I don't have a rader but it looks like around 30+ mph. Pretty happy about it.
The ESC is kind of at the warm side. Would like to connect a fan but don't know how...
CA
why is everyone getting the 2.3mm shaft version..... you are limited on pinions
next time get the 3.2mm ,,, there is a wider range of pinions to use
