PassTime Perigee Build thread
Tower Hobbies
Logged in as Guest
Users viewing this topic: dwaynenancy
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> PassTime Perigee Build thread
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
PassTime Perigee Build thread - 11/7/2007 1:01:31 AM
WEDJ
Status: offline
OK, here goes. I got a PassTime Perigee, and am starting to build it. Don't expect this to be a fast-moving thread, I hope to have her ready by early summer 08. Also, this won't be a stick-by-stick build, just the highlights, insights, and lots of assembly photos.
First impression of the short kit - very nice quality, light balsa, laser cut.
My biggest surprise as I started to assemble the wing - the spars are curved forward! Lots of pins into the board are needed to keep things aligned. One of the plywood dihedral braces needed a slot widened. A word about the spars, they are delicate. Read as in "I broke it several times playing around and fiddling with the ribs"
The center rib has only one supplied, not two as shown on the plans. This rib is out of thicker stock, but not thick enough to fill the slot. I added a doubler of 1/16 balsa to fill it out. Since I'm planning on outboard aileron servos, the center cutout was not needed, so the 1/16 atually strengthens this area.
Photo 1 - center rib doubled
Photo 2 - assembled egg crate
Photo 3 - curved spars
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by WEDJ -- 11/7/2007 3:48:57 PM >
       Post #: 1
RE: PassTime Perigee Build thread - 11/7/2007 1:38:03 AM
Free Bird
Status: offline
Nice to see that a real classic is on the boards! Keep us posted Nic!
FB
(in reply to WEDJ)
       Post #: 2
RE: PassTime Perigee Build thread - 11/7/2007 9:52:55 PM
Dean Pappas
Status: offline
Hey Nic,
I think I need contact info for PassTime.
And to think that I scoured the jungle just to find a set of Perigee plans!
best regards,
Dean
(in reply to WEDJ)
       Post #: 3
RE: PassTime Perigee Build thread - 11/7/2007 10:13:53 PM
Free Bird
Status: offline
Dean,
I've had a set of Perigee plans for a number of years, but no one has asked for a copy!
FB
(in reply to Dean Pappas)
       Post #: 4
RE: PassTime Perigee Build thread - 11/8/2007 12:02:34 AM
Atlanta 60
Status: offline
Looking Good...
Wow...Check that wing out!! That's pretty wicked!!
Looking forward to seeing her come together!!
Have Fun...
Chuck
_____________________________
"A Superior Pilot uses his Superior Judgment to avoid using his Superior Skills." - astronaut Frank Borman
(in reply to Free Bird)
       Post #: 5
RE: PassTime Perigee Build thread - 11/8/2007 8:27:49 AM
vintageflyer
Status: offline
That is looking great WedJ. Your building table looks so neat!
Makes me want to stay home all day and build!
DM
(in reply to WEDJ)
       Post #: 6
RE: PassTime Perigee Build thread - 11/8/2007 1:59:36 PM
WEDJ
Status: offline
quote:
ORIGINAL: Dean Pappas
Hey Nic,
best regards,
Dean
Hi Dean,
Here you go:
http://www.mybloo.com/coosbay/laser/beaver.htm
I actually bought 3 kits. I have sold one to Free Bird, and am building one, but there's one more just sitting in the corner of my shop now if you're interested.
       Post #: 7
RE: PassTime Perigee Build thread - 11/8/2007 2:22:34 PM
WEDJ
Status: offline
Last night I looked at the leading edge of the wing. The original had a perforated sub-leading edge, that's why the tabs are there. The kit does not include this, although it does for the TE. I thought about cutting the tabs off, but then I would have just a butt edge from the sheeting to the LE. Today I'm going to get some 3/32 x 1/4 strip and put them above and below the tabs. That way, the sheeting has a "landing" to glue to, and the LE will have a more solid gluing surface, too.
CA sure makes building a lot more fun. This construction with Ambroid would have been a nightmare of pins, jigs, and weights.
(in reply to WEDJ)
       Post #: 8
RE: PassTime Perigee Build thread - 11/11/2007 3:48:42 PM
WEDJ
Status: offline
Well, I put the LE sub-strips on earlier tis week, but haven't had time to post it until now. Looking at it, I would highly reccomend this step. It forms a continuous gusset between the sheeting and the LE, adds a tremendous amount of strength and rigidity, for almost no weight penalty.
Click for fullsize
(in reply to WEDJ)
       Post #: 9
RE: PassTime Perigee Build thread - 11/11/2007 3:50:26 PM
WEDJ
Status: offline
Also started the stab, too. those little rib feet are delicate. I sanded a taper on them, both fore and aft, and thinned the sheeting a bit. Makes starting them into the tab slots a lot easier.
Click for fullsize
(in reply to WEDJ)
       Post #: 10
RE: PassTime Perigee Build thread - 11/11/2007 4:36:27 PM
vintageflyer
Status: offline
quote:
ORIGINAL: WEDJ
Now I see what you mean w/ the leading edge WEDJ. You are doing one hell of a nice job on this bird.
Please keep sending us notes on your changes. I just got a link from Roguedog to PassTime, I'm getting a Perigee!
DM
(in reply to WEDJ)
       Post #: 11
RE: PassTime Perigee Build thread - 11/11/2007 10:05:16 PM
Free Bird
Status: offline
Looking good Nic! At the rate you're going, you'll have it finished in no time!
FB
(in reply to vintageflyer)
       Post #: 12
RE: PassTime Perigee Build thread - 11/12/2007 2:20:38 AM
WEDJ
Status: offline
quote:
ORIGINAL: Free Bird
FB
I wish. Just bought some carbon paper (had to buy 100 sheets) So I could trace the top sheeting curves onto 1/16 sheet.
       Post #: 13
RE: PassTime Perigee Build thread - 11/12/2007 4:53:22 PM
Free Bird
Status: offline
I've got plenty of carbon paper, I could have mailed you some.
(in reply to WEDJ)
