List of most common rookie mistakes?
Quick list. Come up with what you think is the most common rookie mistake made with any RC Car/Truck/Buggy I'll start off with two.
1) Overtightened gears (spur, diff, etc)
2) Overtightened or sloppy steering setup
FL
RE: List of most common rookie mistakes?
3- not gluing tires (probably not a big problem nowadays with preglued tires)
4- not reading the manual before running their new car.
5- using red loctite
OR
-For kits: Not following the assembly instructions to a "T"/taking shortcuts due to impatience and desire to be on the road NOW
-For RTR: Not giving the vehicle a good once over to make sure everything is where it's supposed to be- Making sure things are thread locked and tight.
-To expand on not properly breaking in a nitro engine: Not tuning it properly/over leaning the mixture and running the engine too hot/running sans air filter
Yea definately forgot the crappy battery bit.. I hate it when hobby shops push those on newbs because it makes the most profit for them and they tell the newb that its "one of the best" so cant really fault 'em.
8- giving up to easily when frustrated
9- not growing with their hobby by using creative tweaks and hop ups that require some work
Who has number 10?
Who has number 10?
Here's one for the rookie racers.
I often see (and made the same mistake myself) rookie racers play the hop up game. Everytime they break something it's replaced with a hop up part. They see themselves slower on the track so they buy a super race mill. Everything has to be bigger, stronger and faster. However, all you really need to do is practice. Not crashing will net you far fewer broken parts. Spend your money on fuel and tires. Go through as much of them as you can. Look for setup tips from your local fast guys, rather than upgrading parts right off the bat. Increase your driving skill to the point where you become dangerous with an RTR, and then you will have a chance to podium.
Good luck, and good racing!
Rob
Rob
10. pouring gas into the tank[&:]
11. not going back to the hobby shop after they buy the car
12. useing crapy tools
13. not mantaining the car(rust is bad!!!)
ON, CANADA
-trying to save money buying cheaper parts that are crutial to a well set up car.
-sometimes trying to go for huge jumps when bashing without much practice. being impatient and never going in rational increments.
-making many changes at a time.. then not being able to figure out which change make the car handle like %^&*$
buying cheap off brand cars because they are adveritzed that they can go 65 mph
starting with nitro instead of electric. (my friend did this)
ORIGINAL: s7jstep1
or geting a traxxas that can go that fast and chrashing it
IN
its a huge mistake when your first car is a nitro kyosho, you bought a kit to build alone when you were age 15, forgot to loctite, superglued some set screws in wrong, had to call kyosho japan to have them ordered, took two weeks to get the parts and when i got them i was sick of building it.
GA
The biggest mistake?
IMHO, it's reading all the internet forums and taking it as gospel.
The net is a great place to start but for goodness sake take everything you read with a grain of salt. Probably over half of what you read is being written by people without much more experience than you. There's good info on the net too but you MUST use your own mind and common sense to make your own decisions.
If you ask why your engine won't start and someone says it's probably a stripped spur gear (yes, I have seen that reply) then use some common sense and analyze it a bit. If someone only owns one vehicle and says that X or Y or Z is crap then ask yourself, "How can they say that" . Are they angry with a company, a friend who beat them, did they own one and have a bad experience or are they just parroting something they read somewhere?
In other words, use the net as a starting place but THINK FOR YOURSELF too.
NJ
ORIGINAL: pguntle
Advice: DON'T GET CHEAP BATTERIES!!!
Turning your radio on during my race. Who's on 61?
Anymore, this is what the sign up sheet looks like. I havn't had problems in a long time...lol
Spectrum
Spectrum
Spectrum
Spectrum
61
Spectrum
Spectrum
Spectrum
Spectrum
Spectrum
Spectrum
61
Spectrum
Spectrum
IN
lol, yea... I will never buy an rc without making sure i have access to parts quickly ever again. I do wish i would have gone electric first.
also, when i finally got my kyosho started, half the bolts rattled off and i wrecked it into a large rock,and i bent the front shock tower on that. had to wait again for the parts for another week.
