NEW Kamitiro models 4x4x4 and 4x4
My Feedback: (25)
IL
T5 - Rhino:
http://www.kamitiro.de/iv3/cms?SID=E...artikel&AID=15
K3 - Spyder:
http://www.kamitiro.de/iv3/cms?SID=E...artikel&AID=62
K3 - Spyder:
My Feedback: (25)
IL
RE: NEW Kamitiro models
K3
Finally it is - the K3 - Spyder series there! The first GENUINE Monstertruck! Our RC-Car-models on a scale 1:6 let each RC-Fahrerherz strike and bring more highly you with your revolutionary Featers to hyper+ventilate. A qualitatively high-quality all-wheel drive with an all wheel steering element this Kamitiroprodukt makes paired the Non plus ultra within the RC-Offroad-range! A balanced, 4mm strong aluminum tub chassis as well as completely abgestrebte foremost and rear axles make the K3 extremely torsionally stiff - for Spyder. It offers a lowest possible attack region to the underground thereby by its narrow base plate form. By the emphasis-optimized arrangement of the building groups (tank, engine, transmission…) the Spyder is perfectly balanced in the refuelled condition and gets in such a way by its very deep emphasis a perfect handling. Very robust chains distribute Kraft 2 clock of engine evenly on the two differentials of the K3 - Spyders. To be stopped it can only with its 2 double disk brakes. The inserted Lenkservo save Sytem provides for more precise guidance maneuvers, without damaging thereby the servo. Its extreme area ability arises in addition as a result of the inserted double shock absorbers. Both with foremost and rear axle fall and trace for each wheel can be adjusted separately. A in series inserted Mielke Resonanzschalldämpfer for increase in output completes this force package from the house Kamitiro. By its modular building method the Spyder is extremely low-maintenance. Thus engine or axles with only few handles can out and again be e.g. inserted problem-free. It will give the K3 Spyder with its revolutionary all wheel steering element in different stages of development of the simple chassis up to the complete RTR version.
T5
The T5 Rhino series offers different RC-Car-models on a scale 1:6 those by its extreme robustness and an uncompromising, direct power transmission captivates. All models in the T5 Rhino series are equipped with the Kamitiro 4WD all wheel system and guarantee thus never dagewesene handling characteristics. Thus the extremely rigid angle framework provides for a deeper emphasis, which by the optimum weight distribution of the building groups (engine, transmission, tank…) still additionally one optimizes and into a more aggressive driving fashion to be immediately converted can. A completely closed gear unit protects this range before unpleasant foreign bodies and provides thus for a longer and clear driving passport. The power transmission is ensured in each case by roller chain on foremost and Hinterdifferential, whereby without a central differential one did, so that Kraft to the axles will transfer 50/50. A new Lenkservo save Sytem, permits more precise guidance maneuvers to the driver, without damaging thereby the servo. To the T5 for example the Kamitiro X-pro-revolution as well as the Kamitiro Concept Four, which is unfortunately not available however at present, belong to Rhino series.
T5
MB, CANADA
Kool Killer That quad steer is neat, lots of aluminum. Are you getting some in? Nice to see you in the forums again, done with your hard labor?
My Feedback: (25)
IL
ORIGINAL: clubin
I asked for two, I'm still in CA working
Alum Cru
I don't know how much they are going to be. I ask if they have any vids
MB, CANADA
RE: NEW Kamitiro models 4x4x4 and 4x4
BC, CANADA
K3 is an FG monster with no roll cage, different side guards to mount the rear steer conversion, with the kami chain drive conversion kit (not heard too many good stories 'bout those[])
My Feedback: (25)
IL
ORIGINAL: mooman007uk
NJ
Personally, I think the 4 wheel steering only looks cool because it's new to us, I don't see any real advantage for it, the video did nothing for me to run out and buy one.
The Kamitiro trucks were always built nice, but I see no reason for 4 wheel steering, they should focus more on there quality control on there 4wd systems.
Moderator
I agree, 4WS is vastly overrated unless you're rock crawling or something. I too would want to see higher quality out of Kamitiros mechanical parts before shelling out the cash they ask for.
ORIGINAL: killermolly
T5 - Rhino:
K3 - Spyder:
T5 - Rhino:
K3 - Spyder:
As for the prices, what are they in USD?
If I should PM you, let me know.
Does anyone know if this site has an English equivalent? Please let me know, I'm considering placing an order with these guys
WA
ORIGINAL: SAVAGEJIM
Thanks a million. Now all I need to do is find a money exchanger program to conevrt euros to USD
a euro is about $1.30 ish credit card rate maybe a bit more.
I know this thread has been inactive for some time, but I was studying the layout of this 4WD upgrade kit. I have a 2speed in my MT and looking at the this kit, it is made for single speed.
I was wondering if it would be possible to mount a 2speed gear set on the forward driving gear shaft?
WA
ORIGINAL: SAVAGEJIM
Yes, that is a concern of mine also. The kit looks like it has alot of black plastics for key structural members, thus allowing for possibly too much elastic flexure. That flexure of course would yield to teh chain derailing. I am thinking to possibly seeing if I can have alum alloy structural members fabricated and fashion chain re-railing guides at teh front and rear chain sprocket areas.
Unfortunately, RCU has way too little info on this kit, I will have to continue my reasearch on otehr sites to find out precisely what teh common problems are.
WA
ORIGINAL: SAVAGEJIM
Heres some info http://www.rcuniverse.com/forum/m_7158452/tm.htm
.................................................. ...........INSTALLATION........................... ..............................................
.................................................P ROBLEMS........................................... ............................
ORIGINAL: Gas jocky
Not one min in and look what happend?? I even used red locktight
ORIGINAL: Gas jocky
Well here is the result of a 5mph impact. This is the Kamitiro **** kit, I am absolutly disgusted with this garbage. Not only the hassles of MAKING this junk work in the first place a minor impact by any other rc on the market and this is the result. At one time I considered buying a Kamitiro 4x4 truck ($2400.) If this is any indication of there quality There is NO way I'm buying anything from them!!!
ORIGINAL: Gas jocky
Here are the parts that broke from my 5mph mistake. Talking with Kamitiro right now and will let you know how it goes.
WA
more photos....heres another 4x4 conversion kit
ORIGINAL: hellya
the kit is expensive but nice .....$1500 for your RTR MT......$1375 for this kit...... $2875
For about the same price you can get the FG MT Competition 4x4
http://www.fgsupply.com/Monster_Off_...ke_clear-.html
MS
I don't know of anyone who purchased one of these. I know I haven't sold any. Lots of money for something that is really not supported here in the US,
