Merlin Turbine Clinic Support for Merlin Turbines is provided in this forum
90mk2 pump limit reached !
Reply
Old 10-05-2012, 01:31 AM
Ian Prentice
Ian Prentice's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 90mk2 pump limit reached !
Hi I have a merlin90mk2 and when I go to full power it comes up "pump limit reached" it did this in my other model and wasn't an issue as I didn't need full rpm ! I am getting 147000.
Ian Prentice is offline
Old 10-05-2012, 01:45 AM
frema
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 90mk2 pump limit reached !
ver simple
go in the menu
go to run parameters
and go the pump limit
you can raiz it to 1000 if you want
but check also your feul filters
maybe they are blocked
frema is offline
Old 10-05-2012, 01:50 AM
PeterCantropus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Reason is that you have a restriction in your fuel line, usually in suction side.
PeterCantropus is offline
Old 10-05-2012, 01:53 AM
Ian Prentice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks will double check fuel lines etc regards Ian
Old 10-05-2012, 02:01 AM
frema
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
did the engine reach his max rpm before?
i that case yes it can be the fuel line
just check it and let us know oke?
regards,
Martin.
frema is offline
Old 10-06-2012, 04:12 AM
Ian Prentice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi I have redone the fuel system new tank fittings uat etc and it still says pump limit reached ! At full power / 147 k the pw is 650
Old 10-06-2012, 07:31 AM
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Send Gasper an e-mail he normally gets back to me within the hour.
Mike
BaldEagel is offline
Old 10-06-2012, 10:33 AM
Sparhawk
Sparhawk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My new Rabbit 100 (close cousin to the merlin) does the same thing. Did it right out of the box. If it's not your plumbing, it's that the pump is either too tight or the pump motor is bad/weak.
I'm going to fly out season with mine then ask for a replacement pump. I am also losing about 2K
DanDan
Sparhawk is offline
Old 10-07-2012, 05:48 AM
joeflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Read post #2. What is your pump limit set to? You shouldn't be getting the"pump limit reached" message unless it is set to 650.
The pump limit on my Merlin 90 is 752. That's the as received factory setting.I haven't checked to see what my actual pump PW is at full throttle butit's never been a problem.
Joe
joeflyer is offline
Old 10-07-2012, 12:30 PM
Ian Prentice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Gaspar has emailed me and hopefully it will soon be sorted !
Reply
Display Modes
