Pershing Missile
UT
Pershing Missile
I've been looking for a Pershing Missile from Estes for many years and still looking so if any one has one or knows of one preferably not built I would be interested in obtaining one.
Gwyl
Gwyl
My Feedback: (47)
RE: Pershing Missile
You can find them on Ebay occasionally, or post a wanted ad on TRF (http://www.rocketryforum.com/).
If you want a REALLY impressive Pershing, try this baby... http://www.polecataerospace.com/pershing_ii_5_5.htm
there is also a nice smaller MPR (mid-power) kit from TLP, see more here: http://www.rocketreviews.com/reviews...rshing_1a.html
Barry
Barry
UT
ORIGINAL: blw
That brings back some memories. I was stationed in a Pershing missile unit in Germany in 1976-1978. Unlike loving to see model rockets fly, you never wanted to see one of those do anything but sit there quietly!
My Feedback: (126)
ORIGINAL: GRB
Gwyl
Gwyl
Hi - I was just surfing the web and ran across your posting in reference to pershing missiles and that you had been with PershingMissiles from 1976 to 1978. I just wanted to say Hi to a fellow pershing missileman and to let you know I was also in Pershing missiles from 1980 to 1983 and was a 21G20and ran the countdown launch Computerin thePTS and also repaired the missile system - I ( along with 29 others from the 3/9th FA at Ft. Sill) wentto Orlando, FLto work with the Martin Marieta Corp. to develop and deploy the Pershing II system and was deployed to Heilbronn in 1983 - I would also like to find a good quality model of the Pershing Missile too.
I have a Pershing Missle. Flown twice. Maiden flight was not perfect. If I remember right it rolled over on its back at about 30'. Then it went about 400-500' getting no higher than 50-60' off the ground. It was like an actual launch I imagine. Well I think this happened because of the cheap balsa nose cone, with washers that are added to it for weight. I think that is why the rocket rolled. Second flight was worse. It went spiraling up about a 100' and came down in a crash. No severe damage. Just ripped off a fin. Flimsy balsa fin from the kit, and another upper fin jammed through the body. Anyway cool rocket. Wish it flew better.
Mystery-
It sounds like (from their own description) the rocket has limited stability and really needs one of those top end engines (F) to get off the rod at decent speed. I can sure understand how a balsa fin wouldn't stand up to the acceleration you have to have. What the builder needs to do is glass the fins and/or replace them with plywood.
-Ron
-Ron
