Ultimate 120
TX
Ultimate 120
I finally got to fly my new ultimate 120 today. It has been ready to run for at least a month, but today was the first decent flying day that we have had. Just a quick note to say that is plane flys like a dream. I have an os 120 4 stroke on it and it pulls it around the sky without much trouble. Its a brand new engine so i need to get it broke in, but when its finally seasoned im sure it will be more than adequate power to have unlimited verticle. Anyone wanting a nice 120 size ultimate should really check into this plane. It not only looks great but will do any trick in the book. Thanks Nitro! you got a real winner here!
Rod
Rod
RE: Ultimate 120
ORIGINAL: rashmore
Rod
Rod
Yup, I have the older model which is still flying.
The older one flies great with the O.S. 1.20 yet it is heavier than yours.
The new lighter version which you have, should be perfect with your combo.
Landings are quite nice.
RE: Ultimate 120
Thats good to hear, should have my ready to fly next weekend, I have BCMA 26cc, didnt have to add any weight to get it to balance and it came out at 10lbs 1oz
RE: Ultimate 120
HI Guys,
I have just bought Ultimate 120. I would like to know, what engine is the best for that model ?
I mean OS Engine of course: 0.91 FX ( 2 s) ; 1.20 AX (2 s) or 1.20 FS (4 s.)
I think 1.20 FS will be OK. [8D]Am I right ?
Best regards
Peter
Best regards
Peter
RE: Ultimate 120
ORIGINAL: peter2102
HI Guys,
Best regards
Peter
HI Guys,
Best regards
Peter
While the plane flies very well, it is NOT "unlimited verticals" so I wish it had a bit more power.
The yellow version of the 1.20 is much lighter and should do well with the 1.20 FS but a bit more engine power may be recommended.
The 1.20AX produces more power than the FS ( more akin to a 1.60-1.80 Four Stroker ) so it should be fine.... if you go this route you'll need a Pitts Style inverted mount muffler though.
The .91 FX would be similiar in performance to the 1.20 FS or there-abouts.
RE: Ultimate 120
to opjose:
so, what do you think about 1.20 AX (2 strock) ? - Is it better choice then 1.20 AX or 1.20 AX will be OK ?
1.20 FS - the price is max - I can pay.
(Ultimate 120 - 4.500 g)
Peter
Peter
RE: Ultimate 120
ORIGINAL: peter2102
to opjose:
Peter
to opjose:
Peter
You ask if the 1.20 AX ( 2 stroke) is a better choice than the 1.20 AX or will the 1.20 AX be OK?
All are the same engine.
RE: Ultimate 120
Sorry,
I mean of course, the 1.20 2-strokes
http://www3.towerhobbies.com/cgi-bin...?&I=LXLGJ0&P=7
and 1.20 4-strokes ?
http://www3.towerhobbies.com/cgi-bin...?&I=LXBY64&P=7
Which one is better for Ultimate 120 (yellow) in your opinion ?
Best regards
Peter
Best regards
Peter
RE: Ultimate 120
Well... the plane will do OK with a 1.20 FS ( 4 stroke ).
But it will have MUCH more power with a 1.20 AX ( 2 stroke ).
However on this Biplane I prefer a four stroke.
So to get the equivalent power as the 1.20 AX, on a 4 stroke engine you would have to move up to around 1.60 CU to 1.80 CU four stroke engine.
A comparison between the 1.20AX and a larger four stroke engine would be more equitable.
As it is the 1.20AX has more power. If I had to choose between just those two, I'd go with the 1.20 AX, but I would be hit with higher fuel consumption.
RE: Ultimate 120
to opjose,
You are right, 1.20AX "drinks" more fuel ... [:-]
It means I will buy .......... 1.20 FS, [&:]because 1.60 twin 4-strokes is very expensive.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBY68&P=7
There is no engine between 1.20 and 1.80 4-stroke from OS.[>:]
Best regards
Peter
Best regards
Peter
RE: Ultimate 120
Flew my 120 today for the first time, the plane flew very well, but would be easy to ground loop if you not ready with the rudder if you hit all the power at once, the 26cc didnt have the power i was hoping for, but this is my first gasser, and i am sure i had it to rich, so i am sure it will do better with a little more tunning
Wes
Wes
RE: Ultimate 120
ORIGINAL: RR24
Wes
Wes
- Try to "toe in" the wheels a bit.
- Replace the tail wheel assembly for one that will permit the plane to sit in a more level position.
In effect you want the nose not to point "up" as much when the plane sits on the ground.
This will have a rather dramatic ( improvement ) effect during run-up.
For a suitable replacement tail wheel assembly WITH an included rubber wheel and aluminum hub at an unbelievable price check this out.
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLLB9&P=7]Tail Wheel Assembly and Wheel.[/link]
Yes you see that correctly... $1.98.
RE: Ultimate 120
Hi guys,
I'v been think about OS MAX 1.20 FS, and I'm afraid - it maybe weak a little. What do you think about it, and what will you say about ZEONAH G23 ?
http://www.horizonhobby.com/Products...ProdID=ZENE23A
or similar,
- better price, power and economy (in my opinion of course).
Best regards
Peter
or similar,
Best regards
Peter
RE: Ultimate 120
The G23 weights about 12oz more than the 26cc i have but power wise it should be about the same, you will have to put all your servo's and radio gear to the back and may still have to add weight for balance, mine weight 10lbs and 1oz, didnt have to add any weight, i went will the gasser to try somthing new, and so far i like it
RE: Ultimate 120
Thank you for answer.
So what kind of Gas Engine should I have to buy ?
(is ZEONAH OK ?)
Take a look at: http://www.hobbycity.com/hobbycity/s...1&v=&sortlist=
for different engine models (26 cc) please.
Best regards
Peter
(is ZEONAH OK ?)
Best regards
Peter
TX
RE: Ultimate 120
Peter,
My ultimate flys VERY well with an os 120 fs on it.
I have also just bought the XYZ 26 cc (c-spec) engine from hobby city. I have not run that engine yet. Its very lightweight and seems to be pretty well machined. Other than that I cant tell you how good a motor it is.
Please note, if you do put a gasser in your biplane, it will be heavier, not just because of the engine weight, but you also need an extra battery pack and switch for the ignition.
If you do buy an engine from hobby city, be careful which one you choose. Look in thier forums (marked Customer community) and read the issues that ALL of thier cheaper gassers have had before spending your money on one.
Also, be sure to seal the covering edges of your plane really well. They use very little overlap and the covering doesn't stick as well as it should around the edges. I had to replace almost all of the hardware that came with the plane to something a little more stout. Believe it or not, with the os120 fs in it my ulitmate came out to 7 lbs 4 oz. I had to do a double take and had it checked on 2 diffrent scales. It is VERY light plane and flys like a dream. I havnt been able to get it to hover, not because of lack of power, but probably to lack of skill and I probably need to move the cg back a little to make it more stable, however after leaving the runway, i can point the nose straight up and it will just keep going. I have no doubt the os will pull it out of a hover without any trouble.
hope this helps and good luck!
Rod
Rod
RE: Ultimate 120
Rod,
Thank you very much for big post, and I have no doubts now.
You are right, extra equipment is necessary for gas engine (unfortunately) I have forgot.
Now I am sure, I must buy the OS 1.20 FS
- 1.9 HP, big torque, economy, guaranty and your opinion of course - say it.
Thank you very much once again
It will be OS 1.20 FS
Best regards
Peter
Best regards
Peter
RE: Ultimate 120
ORIGINAL: rashmore
Peter,
Peter,
With the new lighter version that he has a 1.20 FS will do even better.
A 23cc gasser adds additional weight, so you are offsetting the benefits of the gasser with the added weight, so overall you come out about the same.
ORIGINAL: rashmore
After the clear coat has dried you may buff it again with the dish pad for a fantastic appearance.
Your covering will not lift up again.
ORIGINAL: rashmore
My older 1.20 came in at about 11lbs!!!
ORIGINAL: rashmore
From what you are saying it sure seems worth the "upgrade".
Excellent. A FS 1.20 Surpass III pumped on a 7lb biplane would be amazing.
TX
RE: Ultimate 120
Good luck with it Peter! Dont forget to give us some pictures!
Opjose is a WEALTH of information on the nitroplanes products. I am sure he will be kind enough to answer any questions about building or anything else for that matter. He has helped me alot.
Jose,
The plane is really great. I didnt have to do much more than squirt some glue here and there and replace the hardware (which you suggested) and it came out looking great and flying even better. I think its the best 120 ultimate on the market right now.
Jose,
