OS max 40 Sr Engine
CA
OS max 40 Sr Engine
Got 2 used engines: 1- OS Max 40 SR
2-Magnum GP 40
I am going to try and start them but would like to know what type of plug I shoud use on the OS and also what size props is useable with this engine Also the type of fuel I should use.
If you are familiar with the Magnum 40 I would like to know the same thing.
Thanks, Jim
2-Magnum GP 40
Thanks, Jim
IL
OS max 40 Sr Engine
Jim,
To be honest, both are older than I would have any info, data, or first hand knowledge. Please re-post your questions in the regular engine support forum and hopefluly other modelers can answer you.
