Cannot download any files
I'm running a PC with Vista 32-bit and I straight up cannot download anything using IE7 and FF. It shows it as downloaded but no where to be found on my computer. Changing the folder doesn't work.
RE: Cannot download any files
have you checked its default location?
also i doubt it would do this but see if its hidden, go to control panel, folder options and go to view and check the box to show hidden folders and press ok and look again.
in fire fox do you have the download bar or the popup window?
ether or you should be able to right click on the download and right click and click on open containing folder.
