ParkZone P-51 Mustang RTF
#1276
CA
RE: ParkZone P-51 Mustang RTF
Thanks KAHLOQ,
That is one sweet bird.. I can certantly see having that one in my stable very soon. When I said I wanted landing gear I think i was looking at simply setting up some wire wheels, ie fixed gear with some scale looking wheels. This will allow me not to have to belly land and take off from the ground as well. I know folks like GG have put tons of time and money into modifying these babies into something like the larger bird you showed me. I am actually very impressed, but for now if I can get a warbird for $250.00 or less complete I will go that route. I have been reading all the posts and compiling the apropriate modifications needed in a document.
I have been racing nitro cars for years and one of the things that I and others have learned is that there are no real RTR, RTF models. Most models need you to go through and add all the locktight and double check everything before you put out to race. I think the same should be said for RTF airplanes as well.
My only beef at this point is that the PZ radio system is propriatary.. arrggghhh.. I would lve to spend $30.00 and put in a better servo for the alerons.. Oh well I guess if I go the PZ route I will probably upgrade the electronics in the future..
Also anyone have any bad mishaps while taking off from the ground? Looks like most issues seem to be from hand launching.
#1277
Libertarian, the GWS Micros you ask about are rated at different torque at 4.8 and 6v. This rating is for the same servo and power output depends on the voltage applied to the servo.
Most BEC put out about 5v so you would get approx the 4.8v rating.
I think the GWS Micro is too large for these small models, The weight is 1 oz and a suitable metal geared servo could be obtained at about half that weight. The other thing is torque output, I fly 60 - 90 2 stroke models with servos of only 3.5Kg Torque. Locals here are using JR 371 with plastic gears without problems, (metal gears from JR375 can be fitted if needed.)
I notice on the same site as you suggested. Waypoint
W-092MB High Torque, Metal-Gear
Weight : 10.8g /0.39oz
Torque : 4.8V 2.2kg-cm / 30oz-in
Speed : 4.8V/0.13sec/60
Size(mm) : 24.5x11.5x22.5
Size(inch) : 0.96x0.45x0.90
Motor type : 3-Pole Ferrite
Gear type : Metal
Ball Bearing: Single, Top
I have not seen these but specifications sound about right and the price is similar to GWS.
Gear type : Metal
#1278
The Hyperion P-51 is beautiful on the ground and in the air. A couple of local guys in the club have them. They fly fantastic. But they are expensive to repair if crashed.
I got a good tip from the LHS about the stock gears in the PZ P-51. They have always seemed a little tight. They say to put a little Ultra-Brite or other polishing type toothpaste on the gears and run the motor at low speed for several minutes and then clean the gears and bearing. They say this seats the gears well, reducing noise and increasing power with better gear efficiency. I will try this next time I replace the gearbox and report the results, measured with a tachometer.
I'll be upgrading my Magister to add more channels and then transfer the basic 4-channel receiver into the PZ- P-51 and replace the PZ servos and add rudder control. This will allow differential aileron control, exponential inputs for the controls, and rudder/aileron coordination for turns.
Still trying to figure out some basic fixed landing gear.
#1279
ORIGINAL: dsilver668
Thanks KAHLOQ,
Thanks KAHLOQ,
#1280
CA
ORIGINAL: sd_raptor
This process is known as wepping the gears. As an avid model railroader we do it all the time to clean up the gear mesh on locomotives. Especialy shays which have all those gears.
After you clean the gears put a drop of true flow silicone lubercant n it. It should be silky smooth after that.
I had the same idea for gears...
Kahloq had a great set posted somewhere around page 40 I think..
As for the Hyperion I love the looks but it is a little pricy for me right now. Yeah I know I will probably spend more on the PZ, but dumping $400.00 all at once would freek the queen of the roost.
Someone mentioned shimming the motor down and also using a glass of watter to brake in the motor. Can anyone elaborate on this? Thanks..
#1281
My Feedback: (39)
IL
Hey everyone. I did not bother reading all 52 pages but Since sept. MY 9 cell battery had not been charging right. Even on our Orbit discharge and reflex charge it would only put 100 mha or less in it wile getting hot. We'd plug it in and the prop would barley turn. Yesterday I finely decide to chuck it (recycled at my Dad's work) So should I buy another nine NiMH or go Li-poly? And which Lipoys would you recommend?
#1282
Hi SD RAPTOR,
Hi SD RAPTOR,
dsilver,
The motor break-in is simple. If it is a new motor, solder on some leads. Find a containier large enough to hold the motor with an inch or so of water above the motor. Add three or four drop of liquid dishwashing or hand soap. Power the motor ith about 3 volts - I use two D-cell batteries in series - be sure to run the motor in the same direction it will be turning mounted in the plane. . Let the motor run for about five minutes. The water will be a little grey from the brushes seating. Change the water, add soap, repeat until the water stays clean after five minutes. With a good penlight you can inspect the brushes before and after. When new, the brushes have a pair of "rails" that just barely touch the commutator. After running in, they are firmly seated to the commutator over their full length.
Next step - upgrade to lipos - that makes a HUGE difference in take off power.
Good luck.
#1283
CA
Awsome SD RAptor thanks.. That seems kinda wierd runing a electric motor in water, but I plan to do that on the PZ when I get it. I also plan to switch to lipos straight away. Anything to get a little more thrust out of it should help.
Also if I were to upgrade from the $10.00 PZ motor to another brushed motor are there any recomendations. With out getting the powezone adapter I would need to swap out all of the electronics to acomodate a brushless. I will probably do that anyway at some point. My guess is the better $20.00 servos will make a world of difference. Just kinda erks me that they use propriotary radio equipment so we can't upgrade to a better servo..
#1284
ORIGINAL: love those warbirds
#1285
Hi Dsilver668, I heard u race RC cars for quite a while, and u live in Sunnyvale right?, do u go to any RC tracks? I'm asking because I live in SanJose, and I always go to Morgan Hill track to race my car, so there is a little chance that I might see u before. :-)
Anyway, I had a pretty bad crash on my Stang because my lipo ran out of juice in mid of air, and I tried to land it downwind which caused a tip stall in a very bad attitude, Dang, damaged the whole front end...... A furthur investigation shows the lipo is also gone because I forgot to take out that jumper on the receiver, so....one of the cells is down to 2 something volts....... No wonder it cuts off. BTW, it's a 2200mah, 12C rated lipo, lasted over 20 mins until completely destroyed (most of time WOT). oh well, luckily, it didn't set fire on my Stang.
I got so pissed by my careless, guess I will spend quite some time to repair it.
#1286
My Feedback: (39)
IL
ORIGINAL: GLbiggles
in Australia the PZ 2200 is good value.
#1289
CA
ORIGINAL: nerv
Yup I live in Sunnyvale and work in Campbell. Race a HALO 2 XBOX inspired Jammin PRO and a Avenger 1/8 scale on both. Been to Morgan Hill a few times, but went to the hobby world track a lot, until it closed.
#1290
TX
ORIGINAL: GLbiggles
Gear type : Metal
Gear type : Metal
#1291
TX
Guys check this out!!! New LIPO technology!!!
Altair Nano (ALTI) which has some potentially revolutionary developments in the lipo battery industry. Some of you may have heard or read about this but my guess is that most of you have not.
This company has developed, tested and is beginning mfg for cells that have an operating range of -30C to 250C which far exceeds today's lipo technology. Furthermore these packs can be fully charged in about 3 minutes safely.
They have spectacular cold temperature performance. IF that was not enough they can be charged/discharged 20,000 times as opposed to 100's like today's lipo technology.
Uses for this nano based technology range from hybrid electric vehicles, cellphones, power tools, camcorders, laptops and of course electric flight! Imagine recharging for your next flight in 3-5 minutes? Imagine being able to fly in the snow with a cold pack that was sitting in your car? The possibilities are exciting here.
Some interesting stuff on the horizon...
You can read more on this technology on the company's website: www.altairnano.com
#1292
Nice plane, libertarian!
A few questions:
Where did you get that prop? Selfmade? I assume you have landing gear installed?
And how do you mount your onboard camera? I have one as well, and would love to capture full-throttle low-passes on film. I figured the easiest would be to mount it up-side down behind the air scoop. Just make a small square hole and shove it in there. But I would really hate to make holes in my reasonably new and undamaged plane. ( i didn't mind to much with [link=http://heltpropell.com/bildesider/side5/pages/060305%20394.htm]this plane[/link], though )
Beware of lots of disturbance from the propeller, if that is caught in the cameras field of view. Ruins my film completely. Also ba careful of mounting the camera to close to brushless ESC, I've experienced "waves" on the film due to this.
A few questions:
#1293
ORIGINAL: Libertarian
So you think this one would be the right one for the elevator? 3.5Kg Torque doesn't sound like much, but I guess that is okay huh? THANKS a bunch! I guess I will order one of these soon!
ORIGINAL: GLbiggles
Gear type : Metal
Gear type : Metal
This includes Brushless powered 3d Foamy models with huge control surfaces. Yes I occasionally break a gear but not often. Fit metal gears and the servos are almost bulletproof and work great in 60" wingspan slope racers that are very quick.
#1294
CA
Libertarian
That sounds great.. Having beefy batteries that aren't as sensative, and a longer life span would be awsome. I wonder if the overall weight will be less. Cell technology seems to be getting more juice in smaller cells every day. Imagine having the same power of a S3 2100 but only half the size.. LOL You would get better perfomance and more flight time. 30 minute flights are just around the corner.
On a side note I went out with my friend to maiden his T-REX SE.. That is one sweet little heli.. We got the tracking cleaned up and it is rock solid.
I saw some 15 amp ESC and brushless combos for $40.00 or so. I am not sure if there is enough power there, but throw $30.00 on that for the powerzone module and I am set..
I guess my bigest fear is not having enough power to get out of those pilot induced problems during flight. I don't plan on hovering it like a 3 D aircraft, but knowing I won't stall on take off or during flight will give me piece of mind if nothing else. I think GG's plane should be able to do full 3D with her rightious setup..
My B-Day is on April 2nd so I am hoping my wife will let me pick it up then. Our local LHS's have tons of them in stock, but Hobby Warehouse http://www.hobby-warehouse.com/ has them for $179.00 no tax, plus free ground, and they include a second standard battery for free. That adds up to $30.00 or $40.00 in savings right off the bat..
#1295
TX
ORIGINAL: dagauss
Hobby Zone or Horizen Hobby, I forgot actually but GGs words (I think) the part # on the prop is FS400. I just checked, it's a 9x7.
Comes as a hub and 4 seperate blades. Nice, if you damage a blade you can replace it vs replacing the whole prop. I'm counting on that as I have no landing gear installed. On my ranch there is almost no pavement and not a lot of smooth ground without grass and weeds so I'm counting on landing in thick grass. I bought plenty of spare prop blades just in case but I'll be hoping the prop is stopped by the time it hits the grass, ground every time. If this plan proves a failure I may have to install landing gear and some big wheels and mow an area to land in.
Of course your picture would be upside down. If you were going to do that I'd just make a small hole in the bottom of the fuse and have it pointing straight down for a ground view. In my plane I noticed (before I bought the Multipod) that the Multipod looked like it would fit perfectly INSIDE Frankie and it did! I cut out where his Oxygen mask should be and in back to view the control panel, and button area and viola! Frankie the camerapilot! See pics. Of course I needed a way to access Frankie so I could hit the buttons and remove him to download the video of the flight using its built-in USB port so I made the canopy hinge on the fuse at the front by drilling a small hole thru both and using a paperclip as a hinge.
Beware of lots of disturbance from the propeller, if that is caught in the cameras field of view. Ruins my film completely. Also ba careful of mounting the camera too close to brushless ESC, I've experienced "waves" on the film due to this.
#1296
Well, I said I was using 1/8" metal rod to form landing gear. This did not work as I was unable to get it to bend much( i do not have a vice).....so....instead....I picked up a Parkzone J3 Cub landing gear part at LHS.
http://www.horizonhobby.com/Products...ProdID=PKZ1106
I cut it straight down the middle so I could set the tires farther apart(looks more scale and gives better ground control). I also bent the struts to be perpendicular, and flattend the little square portion where the tire rods fixes to. I found that the wheels that come on this piece were too small, so I also bought 2 1/4inch Low Bounce Du Pro treaded tires. For the tail, I got a Dubpro RC Tailwheel Bracket
http://www.shopatron.com/product/pro...161.5184.0.0.0
I still might actually make the rudder useable...but havent decided yet. I used gorilla glue on the tail bracket and foam safe ca/activator on the main gears. After that set-up, I put some gorilla glue around the metal bracket for additional strength. Once that cures, I will cut and use the 1/8" metal rod and put in some reinforcements. I will take picture when done.
#1297
Thanks for info and pictures. Installing the camera inside the pilot is a great idea! (And we have the same camera, except mine is marked Verbatim.)
I see you get the same picture distortion from the prop as i get, but its still a cool video!
By the way, is that a power switch behind the pilot? I could have used one of those when i fried my RX and motor started running full speed. A bit fiddely to get the battery out while going full throttle, in my experience
I'll get that 4-blade prop, it looks so cool. I probably should put on the [link=http://heltpropell.com/bildesider/mustangski/pages/bildenummer_06.html]skis[/link] again then, but that'll ruin the good looks completely.
#1299
TX
ORIGINAL: dagauss
#1300
Here are pics of landing gear on PZ P-51 using PZ J-3 Cub part. Also shown is the Dubpro tailwheel bracket. I still need to clean up some extra gorrilla glue, but as you can see this plane has taken some belly landings prior to LG.
