What kind of gas?
RE: What kind of gas?
Some guys do ....I don't.... I run 87 octane with 40:1 mix of Red Line oil...and a little Stabil to hopefully off set the ethonol effects...that will soon go to 15%
The higher the octane, the better the gas is for engines that have trouble digesting ethanol. If you want gas without ethanol and can't get aviation gas, you can get ethanol-free gas at some hardware stores. It's very expensive. Some small engines will run on white gas, such as Coleman lantern fuel, which is not gasoline; whether this works for model airplane engines I don't know.
My Feedback: (-1)
ORIGINAL: Top_Gunn
If I remember correctly, Clarence Lee (a recognized engine expert) says that octane ratings for small engines has no importance, low octane works as well as a higher octane. While I have not made any exact measurements with a tack or torque meter, I can not tell the difference in how different octane ratings work. In my engines (mostly Quadras of 35 to 72 cc) , for the last three years (since the addition of ethanol to regular gasoline) I have been running Colman fuel in mine with no detrimental effects or noticeable change in performance. I have had no more carb problems since going to Colman fuel while I was constantly repairing them when using fuel with alcohol in it.
NV
ORIGINAL: Gray Beard
Scoot, buy the kit with the new type of diaphragm.
why dink around.
TOMORROW?????
why dink around.
TOMORROW?????
Yes! Tomorrow!! [8D]
