Epoxy Fuel Proofing
Epoxy Fuel Proofing
There are many posts on fuelproofing with Epoxy. This sounds like a good way to go, but what type of epoxy do you use? Is all epoxy fuel proof, or just certain manufacturers. I am sure some work better than others.
RE: Epoxy Fuel Proofing
I've used any number of brands over the years and can't say that I have seen any difference in fuel proofing. Just use 30 minute epoxy. If you heat the epoxy with a hot air gun, it drastically shortens the set time.
Banned
30 min or 2 hour epoxy. Brand does not matter.
5 min epoxy won't give the work time and goes on too thick if not thinned with alcohol (and then you might as well be using 30 min with none of the chances of adverse effects of low grade alcohol in the epoxy. Same cure time...)
While many get by using alcohol to thin epoxy, sooner or later they will get burned by a non curring sticky mess that is hard to get rid of. If you must use alcohol, use denatured, not medicinal, as the medicinal will have up to 50% water which can cause no end of sticky messes. By far the best solution is to brush on 30 minute or slower and then heat it gently with your heat gun. This will cause it to wick into the tiniest of cracks and crevises providing both strength and fuel proofing as well as speed up the curing time. Anchor Brand also put out a Finish-Cure epoxy which goes on almost like a paint and works well.
To apply a thin coat of pure 30 minute epoxy, I put on a rubber glove and rub a small amount into the wood. Then I throw the glove away.
Can't get much simpler.
Regards.
Regards.
Well, 30 minute epoxy is not fuel proof either, but it is very fuel resistant. People tend to use the terms interchangeably but they are not. Most of the time the fuel, except for the oil has dried up before it can do any damage.
Ed M.
Ed M.
ND
butyrate dope is fuelproof, or at least as close to it as most other commonly used things. Carpenters glue is fuelproof too, just not waterproof, althought titebond II is said to be. CA isn't fuelproof, only kinda sorta resistant. One of the ingredients in most de bonders is nitromethane. You could thin epoxy with alcohol. I'd buy a quart of Everclear. At least if it didn't work you could drown your sorrows.
FL
ORIGINAL: frankflyboy1
Attention! 5 minute epoxy is NOT fuelproof, it will hold up for a short while and then turn into a gel.
I fuel proof the engine compartment with warmed epoxy. I fuel proof the tank and radio compartment with solvent based polyurethane. I just dump some in, slosh it around for a few minutes and drain out the excess. Gives better coverage than trying to reach all the nooks and crannies with bent acid brushes.
- Paul
My Feedback: (48)
For years I have used thin CA to fuel proof firewalls etc. and not one time have I ever had a failure with this method. It's quick and easy and even on some of my older planes the fuel has not even come close to penetrating the wood.
