Ultra Stick 60/standard BB servos?
NC
I am thinking about picking up a Ultra Stick 60. I was wondering if standard ball-bearing servos are adequate for it. I couldn't find Hangar 9's specs for it. One more thing...I am planning on upgrading my radio to a Futaba 7CAP. Will it run the quad-flap option?
Spoon
Spoon
RE: Ultra Stick 60/standard BB servos?
I used Futaba 3004 standards on the Quad flaps and 148's on the Elevator and rudder. I stuck a 6 volt 1800 mah rx battery in though.
My Feedback: (111)
Mine has standard JR 537 Servos. In 1 1/2 years, never had a problem, and this was my everyday plane after I soloed. I used the past tense only because I enjoyed the plane so much that I would not fly anything else! I forced the issue by pulling the engine to put on another plane so I would have to give the other planes in the hangar a chance!
BTW, I flew mine with a 61FX, the engine seems a perfect match for this plane. I'll be putting on a TT 60 Pro when I do put it back up in the air (the FX is now on a Tiger-60).
One thing you might want to consider is to put some fluorescent trim on the top leading edge of both wings. It is sometimes very difficult to tell the top from the bottom of this plane due to the transparent covering.
I have Hitec 605 BB's on the throttle, elavator, and rudder with 4 NES Digitals (they came with my JR8103) on the flaps and aelerons. I am not pusshing them, but just know they are plenty for my US 60.
NC
Hey stuk_at_work, I was thinking about a Tower .75 for it (super saver 4 year warranty). Do you think that is too much? Hangar 9's recommends up to a .78. I want to build as cheap as I can so I am not going 4-stroke. There are a couple of other .70 size I was looking at too, MDS .78, GMS .76, and the SuperTiger .75. I think all are good budget choices. Thanks for the other info guys.
My Feedback: (111)
ORIGINAL: Spoon-RCU
BTW, the only reason the 61FX isn't going back on the stick is because it is now on a never been flown kit built Tiger-60 (winter came early), and I want to reduce the number of unknowns on that plane for it's maiden flight. The TT 60 Pro I am going to put on the stick has never been run, so if I do have break-in issues with it, I am very comfortable bringing the Stick in "dead stick" (No tendency to snap, stalls forward).
NC
Thanks for the info. I checked on Tower's website. The Tower .75 is .6oz. lighter than the OS .61FX. Thats good news...I think.
