Receiver Foam Enough?
PA
Hello:
Have an Aresti 40, Saito 72, JR system, with a TME smoke system installed. Only problem I have is that there is not much room left for the reciever. I have the receiver packed in 1/4" latex foam. The only place I have for it is on the bottom of the smoke tank and when the wing is attached it compresses the latex foam slightly, putting some pressure on the receiver. Not enough to crack the reciever housing or anything like that. But my concern is that vibration, especially from a Saito 72, might be transmitted to the receiver. Or just because it's in foam makes it OK? Any comments will be appreciated.
Glowfuel
Glowfuel
