 servos on a 65"plane >
Old 04-10-2004 | 05:43 AM
LDM
My Feedback: (15)
Default servos on a 65"plane
first time useing multiple servoes
How do you get both airlerons to work in sync
Same question for flaps
Also the servos for the flaps are at leaste 24 " from the receiver , do I need to worry about interferance .
Old 04-10-2004 | 07:11 AM
Default RE: servos on a 65"plane
Ailerons use a Y harness. When you connect your control horns have them oppose each other. Flaps same way except control horns identical. Long extentions are no issue on my plane and its a gasser. Regards G.
Old 04-10-2004 | 04:23 PM
LDM
My Feedback: (15)
Thank I turned my airlerons servos both out and my flaps have arms both facing the left wing, should be ok , thanks agian for the info
Old 04-10-2004 | 06:34 PM
Your very welcome. G.
