Reload this Page >
Sig LT-40 Motor Mount Replacement - same firewall bolt pattern?
Old 06-10-2006, 11:48 PM
somegeek
somegeek's Avatar
Default Sig LT-40 Motor Mount Replacement - same firewall bolt pattern?
Had a rough landing today with my LT-40 and luckily the extent of the damage was only a broken engine mount. Tall grass helped provide a somewhat softer landing. DOH [:'(]
Anyone know of a replacement engine mount that would use the same bolt holes in the LT-40 firewall? Sig has their LT-40 ARF engine mount on their page for $10. If this is the same as the kit I might just order two mount sets. Would be cool to pick up something at one of the LHS if it would work with my firewall holes.
Appreciate any input.
somegeek
Old 06-11-2006, 11:12 AM
Deadeye
Deadeye's Avatar
Default RE: Sig LT-40 Motor Mount Replacement - same firewall bolt pattern?
That's the SIG large motor mount for .19-.61 engines. It is the mount that is supplied with the Somethin' Extra kit too. I just picked up 4 of them from my LHS, because my Saito 82 keeps breaking them from torque. I paid $3.50 each.
Old 06-11-2006, 12:43 PM
Flylow
Like Deadeye said, you can get the same mount at your LHS. Broke mine a couple of times too when I had an LT-40. Looks like you made yours a taildragger. How about some more pics? Did you do a steerable tailwheel?
Old 06-11-2006, 12:50 PM
somegeek
somegeek's Avatar
Deadeye - Is it Sig brand or another brand label for the mount?
Flylow - build thread here - http://www.rcuniverse.com/forum/m_3260903/tm.htm -
Thanks for the feedback.
somegeek
Old 06-11-2006, 01:00 PM
Deadeye
Deadeye's Avatar
SIG brand. Says it right on the package.
Old 06-11-2006, 03:29 PM
somegeek
somegeek's Avatar
Great - thanks, Deadeye!
Old 06-11-2006, 03:34 PM
carrellh
carrellh's Avatar
Take the old one with you to compare. SIG has several sizes and they all look 'about right' when you're staring at them.
Old 06-11-2006, 09:39 PM
somegeek
somegeek's Avatar
Googled and found the right ones on Sig's page... http://www.sigmfg.com/cgi-bin/dpsmar...01F.html?E+Sig
Looks like the SIGEM001 is the right one. Not sure who carries these around here - just might order a few sets and wait.
somegeek
Old 06-16-2006, 04:11 PM
somegeek
somegeek's Avatar
Got my replacements - woot! Ordered (4) sets from Sig on Monday and recieved them on Thursday. $21 with shipping for four sets.
somegeek
Old 06-16-2006, 04:45 PM
Deadeye
Deadeye's Avatar
I'm using Jtec's 8/32 snuf-vibe mount bushings for vibration reduction. Works awesome. I just countersink a clearance hole on both sides so I can get a bushing on each side. Place a washer over each bushing with the 6/32 bolt, and make sure you use red locktite as you won't be able to tighten the bolts like you normally would. It only adds an 1/8 inch or so to the length.
Old 06-19-2006, 10:20 PM
D-LOCO
Broke a couple of these on my LT-40 due to rough landings.
I finally just glued the last broken one with JB weld and bolted aluminum plates on the sides for re-inforcement.
Hasn't broken again but that could be because I finally learned how to land it
Dave
