Plans for Break in Bench?
My Feedback: (12)
CA
Does anyone have any plans or ideas to build a mount for breaking in engines? I have some ideas but not sure where to start. I have a good solid workbench to attach it to. I have seen the kind you buy but I think I can build one to better suit my needs. I am mainly going to break in 4 strokes .91 or larger. Any comments or pictures of your benches would be appreciated & welcome.
RE: Plans for Break in Bench?
This one can be C clamped to a work bench or clamped to a Workmate and taken outside... Fulfills my major requirements - simple, easy and cheap
My Feedback: (82)
OH
I have a very nice Engine Test Bench that I built after looking at one at http://airfieldmodels.com/informatio...s/break_in.htm
I went to sears and bought a 'tool stand' I think that it was made for acting as a table for a scroll saw or table mounted bandsaw. It came with some particle board crap for the top and for the shelf. I went to Home depot and bought a nice pine board for the top and the shelf...stained them then sealed them.
For the mount I used a PSP engine test stand (http://www.pspmfg.com/EngineTestStand.html). For Bigger engines you can get a backplate mounting fixture for the PSP stand. In the end you will have a test stand that you can use for any model airplane engine out there (piston engine) that is safe and at a convenient height for making ajustments. I will post some pictures of it later, when I am home from work.
Chris
Chris
My Feedback: (12)
CA
Jim,
h
Looks simple enough. I just need something easy enough to break in engines without spending $100. I do like the one that you can buy and will eventually get one but right now I'm just trying to save up for some retracts. Thanks for all your guys ideas!
h
ORIGINAL: Nitrodan73
Jim,
Jim,
IN
Perhaps not in the budget at the current time, but check the stand out at http://www.pspmfg.com/. Well constructed and handy to use. I like mine.
I get a motor mount that fits the engine and then screw
it to a big heavy saw horse. I strap on the fuel tank
with rubber bands and have a push rod for the throttle.
If I'm running anything larger than a 1.20 I throw a 8"
cinder block on the built in shelf.
Not fancy but it's worked out fine for more than 25 years.
Simple,functional and inexpensive.
Roby
Roby
ORIGINAL: SMUGator
Looks good, Jim.
Who makes the motor mount?
Tom
Looks good, Jim.
Tom
Used the Tatone/MECOA - PN 51612 .049 - .80 size - $17 plus shipping... They also make a .30 - 1.5 version, but about twice the $$
http://www.mecoa.com/tatone/teststands.htm
Cheers!
Jim
