After run oil for Saitos
RE: After run oil for Saitos
I wouldnt do that (might attack some seals no?)
Umm if you read the book it says you should sue some airtool oil before the first start down the push rod tubes so i just throw some airtool oil in them as i KNOW it wont hurt anything.......
just my opinion and i see no reason to change the oil is very cheap...
Steven
Steven
My Feedback: (16)
SC
That's right. It works great as an after run oil.
ORIGINAL: Kevlar
ATF - Automatic Trans Fluid correct?
I wouldn't think you used Alcohol, Tobacco, and Firearms - although, the thought has crossed my mind on some temperamental engines ...the 'F' in ATF that is...
