Irvine 46 Vertical Prop?
Best prop for an irvine 46?
I have it on a Black horse Super air. I want MAX vertical if not unlimited on this engine?
Would you recommend the 12.25x3.75 or 12x4?
1 Post
RE: Irvine 46 Vertical Prop?
Are you talking about pulling out of a hover or from a normal forward flight ?
The two props you mentoned are ideal for hover/3D stuff. However I suspect that you might do just as well with an APC 11 x 5 from forward flight.
As I understand props the higher the pitch the less speed but the more pull as in vertical.....however if you want vertical you need to either lighten the airplane, or increase the size of the engine...there is only so much a prop can do..perhaps a 55AX
ORIGINAL: berrs003
