CA glue
OH
CA glue
[X(] is this stuff actually good for you to breath and absorb into your system? i have noticed the past 2 weeks....i have been building a taylorcraft....i cannot taste my food.....my sinuses are plugged up....i blame the ca glue. balsa dust never bothered me before...till i used ca glues. any advice on health issues here? i use gp yellow resin where i can....[:@]
IL
RE: CA glue
Some people actually never have a problem and are immune to its affects all together , others develop problems after a long time ,some right away with a moderate to serious reaction to it , but the short answer to your question is....... yes CA is hazardous to your health. both the fumes and breathing it in can be harmful , if I were you I would better ventilate the area I am working in , a big fan in a window blowing outwards can be helpful
NY
RE: CA glue
Ed
I think you know the answer to your question; no. I hate CA but I use it very sparingly. I take my time building so yellow glue works great for me. I recently picked up a built but uncovered plane built with CA. There are so many poor joints and bad sheeting areas that I will probably have to make a new wing. I also suspect that the CA joints won't last like a yellow glue joint. CA seems to turn to powder in time. Even the cheap ARFs seem to be made with some sort of glue that fills gaps, not CA. I don't react to CA, I just don't like its properties.
RE: CA glue
ORIGINAL: edmoor
The weird thing is that I have never been the allergic type, not even to poison oak. My two cents here, stay far away from CA.
Regards
My Feedback: (15)
OK
RE: CA glue
If I just get it on my fingers, I'm laid up for about 5 days worth of sinus problems. I threw out all my CA and I have a 1/5 scale Bf-109 build coming up. I've had excellent results with Titebond and SIG glues, so that is what I'll use. I too tried the cartridge filter mask and good ventilation, but if I come into skin contact with it, that's enough to make me sick.
Jesse
Jesse
