Question about T10
Question about T10
Hello guy's,
I have a question about the T10
I would like to have the following information before buy it because my dealer can only sell me the T10 CHP.
I would like to know if it's possible to buy a T10 CHP and use it in CAP mode for my airplanes as the old FF9.
Does the T10 CHP has the airplanes programs in it's memory as the T10 CAP ?
Thank you for answers.
Best regards
Alex
Best regards
Alex
My Feedback: (15)
OK
RE: Question about T10
Yes,
the Futaba T10CHP or the T10CAP both have all programming for airplanes, (ACRO), gliders and helicopters. The difference between the two is certain switches are in different locations on the heli version compared to the airplane version, and the CHP defaults, (powers on), in the heli mode. Also the throttle is smooth on the CHP, with no ratchet feel to it. You can actually change most of the switches to do what you want and where you want them, and you don't have to use it the way the factory programmed it, in other words, you can customize it to work the way you want it to.
Jesse
Jesse
